I use a floating HTML window to perform fast translation with Google Translate.
I open this window with a Keyboard keys combinaison trigger.
Inside the field to enter the text to translate, all the usual keyboard shorcutcs randomly do not work (CMD-A, CMD-C, CMD-V).
For example if you want to paste a text from your clipboard, when you press CMB-V you will have a "bang" sound from macOS, exactly when you try to paste a text on your desktop.
I am pretty sure that those shortcuts worked in the past.
- Type of Mac: MacBook Pro 2015
- macOS version: 10.15.4
- BetterTouchTool version: 3.373
