I would like to have a floating icon that tells me if my computer is in DND. It will go away when its not. Is this possible? I tried it on BTT and can't figure it out.
you can use the "on script output did change" triggers:
script:
let dnd = await get_number_variable("SystemDoNotDisturbState");
return dnd;
If you need a specific focus mode you can query the " focus_mode variable, however that requires you to give BTT full disk access in system settings
let mode = await get_string_variable("focus_mode");
return mode === "sleep";
