Fix double typing (butterfly keyboard)
Hi dude's,
(Just an excuse in advance: I am no native english speaker.)
I've had/have a big problem for some time and may have just had a brilliant idea.
My butterfly keyboard is %&/$%
My "b" and "n" key is broken...
My tipping looks like this (if I do not correct it):
This is ann nexample typing with my bad keys.. I am now typing a few times "space" annd "n":
n n n n nn nn nn n n n n nn nn n n n n n n n n n n n n n n n n n n n nn n n n n n n n n n n n n n n n n n n n n n n n n n n nn n nn n n nn n nn n n n n n n n n n n n n nn n n n n n n n n n n n n n n nn nn n n n n nn nn n n n n n n nn n....
And "space" and "b":
bb b b b bb b b b b b b bb b bb b b bb b b b b b b b b b b b b b b b bb bb b b b b b b b b b b b b b b bb bb b b b b b b b b b b b b b b bb b b bb b bb b bb bb bb b b b b b b b b bb bb bb b bb bb b b b b b b bb b bb b b b bb bb b bb b .....
So sometimes it s typing two letters instead of one.
My idea:
Is there a way to tell my mac that he have to ignore double typing withinn 0,XX seconds??
Hey @Basti, I don't know if you can do this with BetterTouchTool, but you can try this app: https://unshaky.nestederror.com
It has been developed exactly because of this issue with the butterfly-keyboards.
I suggest you just get it fixed for free at apple...
They replace your whole lower case, so you get new keyboard, new enclosure, trackpad, touchbar, speakers, battery (yes!) and etc.
Takes about two days. Though I guess this tool is needed if the warranty is expired
If you go into key sequence/typed words you can record the "nn" or "bb" as the trigger and set the max pause between keystrokes to .05 seconds.
then make the action typing a single "n" or a single "b"
I've attached images below and it has worked perfect for me.
I'm going to use this until I can afford to spend a few days without my macbook for the keyboard repair
I’d definitely recommend unshaky instead:
@cpadjacent this works! I wanted to avoid installing another app on my system. I found that you don't actually need the subsequent action, just set "Delete typed characters after recognition. Number of characters to delete" to 1. This simply deletes the 2nd unwanted character:
