Finger tap gestures not always triggering
For my browsers (Chrome, Safari, Brave), I'm using the "2 finger tap" and "3 finger tap" gestures on my trackpad to open and close tabs, and often, the first time I tap, the gesture does nothing, like it was not recognized / triggered.
If the gesture has been recognized and worked, then it will work flawlessly if I keep on using it 20 or even 30 times in a row, but if I stop, the issue might happen again. It might look like a non-issue, but since these are gestures I'm using a lot, it becomes very frustrating pretty fast.
I added a HUD overlay for both actions and it is not displayed when the action doesn't work, so the issue is not related to the shortcuts associated with the gestures, but rather with the gestures not being recognized themselves.
Happens exactly in the same way on both the trackpad of my MacBook Air M4, and the Magic Trackpad (USB-C) paired with my MacMini M4.
  • BetterTouchTool version: BTT 5.444
Up, issue is still happening very often, very frustrating :frowning:
