BTT comes with this great behavior of displaying a palette/menu when multiple actions are assigned the same shortcuts. This is absolutely great allowing some sort of two level action trigger.
Encouraged by this behavior, I thought of exposing a series of Javascript transformers using the same shortcut. Right now though, all "Transform & Replace Selection With JavaScript" are displayed with this exact label making it impossible to differentiate.
The feature suggestion is that when showing the palette/context menu for "Transform & Replace Selection With JavaScript", use as a prefix the "Transformer name". That would allow for differentiating between the different transformations.
with gratitude for the app and considering this feature,
Alex
