Feature: a metric for "Performance Toll" on each trigger
Over the last few months I've accumulated many triggers which I made myself - for myself, tailored to my needs. I learned to solve every little inconvenience with a trigger to patch those QoL needs allover the OS and in various third-party apps.
though theres no doubt that some of my solutions are probably very clunky and in some cases overkill - and I have a rising suspicion that ive accumulated performance tax on my everyday usage with all those triggers.
I cant tell which triggers are completely fine and harmless to have around, and which ones activate 1000 times a second for whatever reason or require a very high load of performance either by nature or by my own bad implementation/incorrect usage…
I wish there was a more refined view - just like the - “recently used” which is definitely helpful; but also one that can mention if a trigger is “unhealthy” for performance - triggers suspiciously too often / or simply drop performance in general.. trying to hunt these conclusion with the Activity Monitor would be inefficient…
I just wanna be able to pinpoint what causes those odd stutters / random frame drops / non-smooth experience here and there, to fix/disable it…
if its something that is realistic to implement that could be very useful I believe!
unfortunately that is very hard to achieve, it really mostly depends on the action that is being executed. For the triggers, pretty much all of them are made to be very performant but for the actions that is usually impossible as they will have external side-effects.
The only thing that could impact the performance of triggers are advanced trigger conditions because they are evaluated at the time of trigger-recognition.
Possibly the recently updated usage statistics view can give some clue about the amount of triggering:
