Export Preset problem
The following apple script code saves the preset as "MyPreset.bttpresetcompressedzip" instead of "MyPreset.bttpresetcompressed"
export_preset "MyPreset" outputPath "/path/folder" comment "NoComment" link "https://NoLink" with includeSettings and compress
The following code saves the preset as "MyPreset.bttpresetzip" instead of "MyPreset.bttpreset"
So it seems that the extension is being always saved adding "zip" at the end, and it can't be imported correctly. Removing the "zip" characters from the extension fixes the problem and the preset can be imported correctly.
I 'm using macOS Sonoma 14.7.6 and BTT 5.468
These might be related... strange double extentions
15.5 (24F74) BTT v 5.484
@Max_Megalon how do you turn to blurred a part of an screenshot?
Hallo @jordikt
I am using CleanShot X... :sign_of_the_horns:
@Andreas_Hegenberg did you see this issue?
For the apple script command please put the file name into the path, it currently doesn't handle this automatically:
tell application "BetterTouchTool" to export_preset "MyPreset" outputPath "/Users/xxx/Downloads/test.bttpreset" comment "NoComment" link "https://NoLink" with includeSettings
Done, thanks!
