I am trying to export my master preset so I can import on another machine. Only 2 of the 30+ triggers are exported. It's pretty clear that the problem is with the export, not the import, because I can see the .bttpreset file only contains those 2 triggers. I've tried exporting with & without settings. Tried restarting etc. BTT 4.062 (2778) on Ventura 13.2.1 (22D68).
Are you sure they are all in the preset you are trying to export and not in some other preset?
If so, please go to Help => Export Diagnostic Debug Data and send the result to me via andreas@folivora.ai, then I can try to reproduce.
Ah. You're right, this was my mistake. I had two presets labeled "Default" somehow, and I assumed that the master preset was the only active one, so that was the one I was exporting.
Anyway thanks for the quick response and this fantastic app!
