Example terminal command for custom context menu item not working
Custom context menu item "Create New File" using the example terminal command that appears in the menu when configuring context items (touch "{BTTFinderContextMenuTargetPath/newfile.txt}") has no effect.
  • Type of Mac: 2020 M1 MacBook Pro (w/ Touch Bar)
  • macOS version: 15.3 24D60 arm64
  • BetterTouchTool version: 5.169 2025020213
