Hello everyone,
I just started using BTT and ran into some problems.
I cannot use Escape key while running BTT. It still works though, if I use Shift and Esc at the same time. How can I convert back to normal Esc key ?
When I use BTT as a default (replacing the original Touch Bar functionality), it appears to heat up my Mac. The fan kept running like crazy to cool down my Mac. I never thought BTT would fry up my Mac way more than using Final Cut Pro X. Is there anyway we can fix this ?
Thank you for your help,
Missionary
You most likely have configured an esc button somewhere in the keyboard shortcuts section but not assigned an action.
For the cpu usage: this completely depends on your BTT configuration or presets you are using. If they are running many scripts it will cause bigger cpu usage
Thank you for your quick reply. I just fixed the problems. I just went to Old Configuration UI and disable Esc key. And if I don't run BTT configuration, it is fine.
I am also having a similar issue. My MacBook Pro is getting heated up and fans are running like crazy when my Mac is connected to the charger and the lid is down. I checked out the 12-hour power section in the activity monitor and found that btt uses a lot of energy. Then once I closed the btt, the problem got resolved. I have checked any battery-related settings for this and doesn't seem like a problem might be arising from there. I am using the latest Aquatouch tool preset and didn't do much of a tweaking. What could be causing this issue?
