The touch bar is not responsive while I'm in app switcher mode (i.e. when I hold CMD + Tab to navigate through my open apps). With the native touch bar configuration, I typically relied on hitting "esc" to get out of the view.
MacBook Pro Touch Bar
N/A
Type of Mac: MBP 13" 2016
macOS version: Mojave
BetterTouchTool version: Latest
Unfortunately this is a system limitation without a known workaround (macOS disables all Touch Bar apps while Application Switcher or Mission Control are active.)
I recommend to remap caps lock to esc in System Preferenes => Keyboard => Modifiers
No, I don't know of a way that can detect whether app switcher is active.(besides tracking keyboard and mouse input and inferring that, but this is not reliable)
Hey in case if anyone is interested, this also was a thing stopping me from fully replacing the native touchbar, but since the only way to get around this is to use hardware buttons i use the following combination to emulate "Esc" press:
I've seen in a GitHub issue a person proposed using cmd+` to emulate "Esc", since this button is so close to "Esc" but this does conflict with default OS behavior: switching between app windows.
So i added "Fn" button and it's working great for me: Fn key is very easy to press with your pinky finger when you're reaching to Esc (or ` in our case) with your other finger to close app switcher.
And most importantly this doesn't conflict with any OS key combo
In the newest Mac OS X and BTT it seems once CMD+TAB is pressed and CMD continues to be held, CMD+1 will exit and CMD+` will go back and CMD+TAB forward. so ESC isn't needed.
