Another question
I'm using the Alpha version of BTT (v2.604), and trying to get a bunch of shortcuts on my touchbar for Minecraft. The issue is the key combinations it requires is a horror - for example F3 + I (full list here: https://minecraft.gamepedia.com/Debug_screen under "More debug-keys").
The Alt+F3 etc all work fine.
The only thought I have had is AppleScript, and I have been trying things such as this (commented out lines are more combinations):
key down (key code 99)
#key down 99
delay 0.1
keystroke "i"
delay 0.1
key up (key code 99)
#key up 99
end tell
This testing has been in the "Script Editor" app, and running from there (after a short delay), and I'm finding it's just moving me around or pressing other keys (very weird really).
Obviously using the built in "Custom Keyboard Shortcut" does not capture this weird combination, so wondering if anyone here has any more ideas.
