I'd like to create a shortcut to add my iPad as a 2nd screen via system preferences -> displays -> "+". After a restart I have to do that each time manually. Is there also a way to separate both later on?
I think you can do that via the menubar control center as well. (Don't have my iPad with me to check)
I have a script (not mine...) which is using the control center...
# for a german system use : "Kontrollzentrum"
tell its application process "ControlCenter"
tell its menu bar 1
-- click on and open Control Center drop down
tell (UI elements whose description is "Kontrollzentrum")
click
end tell
end tell
-- interact with Control Center window
tell its window "Kontrollzentrum"
delay 0.5
-- click screen mirroring button
set screenMirroringButton to button 2 of group 1
-- click screenMirroringButton click doesn't work
perform action 1 of screenMirroringButton
delay 0.5
set myScreen to checkbox 1 of its scroll area 1 of group 1
perform action 1 of myScreen
end tell
end tell
end tell
Once you got it working, this might be nice as well
(move a Finder window for example to the iPad screen (next monitor)...
Yes, it's just around the corner. Awesome, simple. thanks.
@Max_Megalon The 2nd one is interesting, indeed! Thank you ![]()
