For nested triggers inside an existing trigger the Enabled checkbox does not work. When I uncheck the enabled box for these sub-triggers the sub-trigger still fires even though it should be disabled. I have to completely delete the sub-trigger to get it to stop firing when the top level trigger fires.
Tested with keyboard triggers only!
Even though I have unchecked the Enabled box the second line will still trigger unless I delete it.
- Type of Mac: macbook pro
- macOS version: latest
- BetterTouchTool version: latest
