Enable sound (ding/bell/notify/etc) upon completion of sequence
Please create an action that generates a sound upon completion of a task. I have tasks that involve multiple actions and with DelayNextAction in place to keep it from running faster than the system can keep up the whole sequence can take up to several seconds to complete. It’d be nice to have an action within BTT that I can set at the end of the sequence so I know it’s complete and I can proceed with whatever next step applies, whether manual or a subsequent task sequence.
Thanks.
good idea, for now you can easily use the afplay command line utility:
afplay /System/Library/Sounds/Glass.aiff
Apart from Glas.aiff there are
Submarine.aiff
Basso.aiff
Blow.aiff
Bottle.aiff
Frog.aiff
Funk.aiff
Glass.aiff
Hero.aiff
Morse.aiff
Ping.aiff
Pop.aiff
Purr.aiff
Sosumi.aiff
Tink.aiff
Of course you could also make it speak some text using the say command
say "done"
Many thanks for that :-). I have been calling a Keyboard Maestro macro to play sounds for the same need the OP specifies.
Works perfectly! Thanks! (Still be nice to have a native BTT solution for that, right? :slight_smile:
