Thanks for adding Low level key remapping. I can finally stop uing Karabiner for remote desktop remappings.
One minor thing I've noticed is that the Enable/Disable Selected Trigger doesn't seem to work for Low Level Key Remapping. It's still enabled when the app says it's disabled.
After deleting the trigger it correctly reverts to the default key.
Built-in keyboard
- Type of Mac: Apple M1
- macOS version: macOS 15.0 (24A335)
- BetterTouchTool version: 4.9992
Thanks for making this app. It really makes using a Mac much more pleasant.
