how can I do it ? I need it for my use case but couldn't really find a way to do it.
I have tried this, but I don't know how to use the X and Y metrics, there is no info on how to use them.any tip is appreciated
that's the x/y axes, e.g. if you want to scroll up the Y value needs to be positive. If you want to scroll down it needs to be negative. If you want to scroll left X needs to be negative, right positive.
I see, thanks. is there anyway where it keeps scrolling smoothly for certain amount of time before it stops ?
great. thank you ![]()
