Is there away to emulate a TAP on keyboard? More like a shortcut that emulates a Tap on the trackpad
I had a gesture that worked really well before reformatting my Mac but is not working after reformatting my Mac.
Two finger fix tap left: this would bring the App switcher
Attached additional action: Delay by 26 seconds
Attached additional action: right click
This would allowed me to scroll with two fingers on all open Apps, once I get to the app I wanna open I release my two fingers and BAM it would open.
But after reformatting the Right click doesn't emulate a tap anymore. without a tap after the initial tap my two fingers wouldn't let me scroll.To make the scroll happen I need to double tap. So I'm looking for an alternative to emulate a Tap with a shortcut key
I tried that before, moreover tried all the Mouse click actions and nothing emulates a Tap. I wonder what would had happened to my previous set up. I didn't touch anything. all I did is import all my Master Preset to the clean reinstall of BTT.
What this allowed me to do is activate the App Switcher(use special application switch. Checked)
With the third finger I tapped BUT leave my two fingers on the Trackpad then 0.26 seconds delay and after Right click so this Allowed me to scroll with two fingers on all the opened Apps, ( The Right click acted like second Tap) it doesn't matter where my cursor is at, I was a able to scroll with easy, once I found the app I would like to open I released my two fingers and it would open.
Question for you, what would a newly BBT default settings might have changed?
Yes I forgot to mention the version that worked on was 3.206 (Catalina. MBP 2013)
What changes you made to app switcher or scroll or Mouse click actions, if anything?
I copy and pasted "defaults write com.hegenberg.BetterTouchTool specialAppSwitcher YES" and enter and it just shows this after. and restarted BBT and still it doesn't work.
ah interesting behavior.
I can also make it scroll by switching from the right two fingers to the left two fingers.
I think I should be able to allow it to scroll immediately but I need to do some debugging here to see what's happening internally (I think it has been 10 years since I touched that code :-))
Yes it took me awhile to get this right years ago. Wanted a fast and easy way to bring up the App switcher and scroll through.
It went like this.
Two finger fix, tiptop left. then just scroll through my apps swiftly, release two fingers and boom app opened in less than 2 seconds.
The key here is to ACTIVATE the scroll somehow.
YES, would be awesome to just have it scroll it immediately with out additional Actions attached. As a developer I'm sure you are able to get around it.
