Using an apple script on a cron to update a .txt file based on json endpoint data output
set targetFile to "FILE_PATH/file.txt"
set webhookUrl to "JSON_ENDPOINT"
do shell script "curl -s '" & webhookUrl & "' | jq -r '.txt // .' | awk 'BEGIN {print \"async function retrieveJSON() {\\nlet items = \"} {print $0} END {print \"; \\n\\n return JSON.stringify(items);}\"}' > " & quoted form of targetFile
The JSON output has Emojis
That file is the source for a JSON Menubar Custom Context Menu
First update of the file using the script, I can see the Emojis, as soon as I connect it with BTT for that Context menu, the emojis stop rendering properly:
The issue isn't with the script. It only occurs with files linked to BTT. When I use a completely new TXT file in the Downloads folder, emojis display fine. However, once I link it with the BTT custom menu, the emojis stop rendering correctly.
you mean it renders incorrectly in BTT, or does the actual file change? (BTT doesn’t modify your files)
Have you tried changing the script as shown above? BTT requires UTF-8, other file encodings will render special characters incorrectly.
If you mean running the script outside of BTT works, but running inside of BTT - that is possible because BTT doesn’t read your environment variables by default. These include the default encoding
Current file I've been using in BTT: [this file now also shows utf-8 for some reason..]
before connecting to BTT : text/plain; charset=utf-8 (Emojis working fine)
after connecting to BTT : text/plain; charset=us-ascii (Emojis not rendering)
New file I've created and linked to BTT:
after connecting to BTT : text/plain; charset=utf-8 (Emojis not rendering)
Note: When I open the txt file using sublime text, it shows the emojis no problem.
