Capture screenshot in clipboard, then edit image using clipboard manager.
After click "done" or "cancel", btt is quit or restart.
I try clear history and reinstall btt but, still has problem.
- Type of Mac: MacBook Air m1, MacBook Pro m1
- macOS version: 12.4
- BetterTouchTool version: 3.781, 3.808(alpha)
