Downgrade Help: macOS Catalina 10.15.7 no longer supported
First post here, I have been using BTT for many years but since Dec 6th I can no longer open my copy. I assume it has automatically upgraded further than my Mac OS can support.
I am running macOS Catalina 10.15.7
When I try to open BTT version 4.932 it says: "The application requires macOS 11.0 or later."
Is there a way to downgrade and if so, which version should I reinstall?
Thanks,
Kieran
this one should work
https://folivora.ai/releases/btt4.926-2024120301_last_macos_10_15.zip
