BTT has a button "Restore Settings from backup" in the menu. Does BTT auto backup the settings? If that's the case, how and when it's done?
BTT creates an auto-backup when upgrading to a new version or when importing a new preset.
Would be nice to have a certain chosen periodic and/or ad-hoc backup proces where all presets with triggers and settings are backuped. In the current situation (as far I've seen v. 4.789) you have to click per preset what you want to backup
you can always just backup the ~/Library/Application Support/BetterTouchTool folder
E.g. create a task that zips that folder once a day or something like that
Right
See here how to do it!
