Dock widget - running apps without running indicator
I would like to be able to turn off the indicator for running apps in touchbar dock widget. I want to see only running applications where badges are on the icons, without indicators, which are then unnecessary.
And if you would also give the widget a background color and not just black space.... :wink:
Will both be added soon!
