In an app called HyperDock they have a helpful gesture where you can show/hide that app's windows by scrolling up or down on the dock icon with a mouse or 2 finger gesture on trackpad. Unfortunately the app silently crashes within minutes on 10.15.2 and it's hindering my workflow.
Group & Top Level Triggers: Scroll Down (Normal Mouse Configuration: Advanced → Trigger Conditions: Trigger while mouse over Dock)
Actions Assigned to Selected Trigger: Activated Currently Hovered App in Dock → Keyboard Shortcut: CMD + H
Scroll up on app icon to show:
Trigger: Normal Mouse
Group & Top Level Triggers: Scroll Up (Normal Mouse Configuration: Advanced → Trigger Conditions: Trigger while mouse over Dock)
Actions Assigned to Selected Trigger: Activated Currently Hovered App in Dock → Left Click
Note: CMD + H doesn't hide floating window types. Photoshop already has CMD + H registered to another shortcut so you will need to specify Photoshop specific binding of CTRL + CMD + H.
It would be nice if the author of BetterTouchTool can investigate HyperDock and see how their hide/show options functions because it works on all types of windows and no matter what shortcut is already assigned. Or hell, even a simple "Show / Hide Currently Hovered App in Dock" to work frictionlessly like HyperDock.
