Distributed Notification for change in Focus mode?
Has anyone found a notification that detects changes between different Focus modes? While _NSDoNotDisturbEnabledNotification effectively indicates when any Focus mode is activated and _NSDoNotDisturbDisabledNotification signals when any Focus mode is deactivated, I am unable to locate a notification specifically for detecting transitions between individual Focus modes.
no, there is no such thing. I think the only way is to poll this information.
There is the focus_mode variable available in BTT that can be polled (requires BTT to have full disk access)
For one of the next alphas I'm adding a "File Did Change" trigger, which maybe could be used by monitoring the ~/Library/DoNotDisturb/DB/Assertions.json or ~/Library/DoNotDisturb/DB/ModeConfigurations.json file
5.286 alpha adds a "File or Folder Did Change" trigger to "automations, named & other triggers".
I think this one can be pretty useful. It sets these two variables on change:
BTTLastChangedFileOrFolder
BTTLastChangedFileOrFolderChangedType
thank you, Andreas!
@Andreas_Hegenberg I don't know if it's related, but as soon as, or shortly after starting to test the "File or Folder Did Change" Trigger, BTT crashed and now I'm no longer able to open the BTT app. I've restarted my Mac and this hasn't resolved the issue.
I see in the Console app that BTT is crashing frequently:
I see in the logs that No numeric part found in the filename. is logged frequently:
2025/03/28 00:22:24:336|ASL|Extracted build number: 2025011301|
2025/03/28 00:22:24:336|ASL|Extracted build number: 2025011004|
2025/03/28 00:22:24:336|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:336|ASL|Extracted build number: 2025021902|
2025/03/28 00:22:24:336|ASL|Extracted build number: 2025030306|
2025/03/28 00:22:24:336|ASL|Extracted build number: 2025020204|
2025/03/28 00:22:24:336|ASL|Extracted build number: 2025030501|
2025/03/28 00:22:24:337|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:337|ASL|Extracted build number: 2025010701|
2025/03/28 00:22:24:337|ASL|Extracted build number: 2025011801|
2025/03/28 00:22:24:337|ASL|Extracted build number: 2025021218|
2025/03/28 00:22:24:337|ASL|Extracted build number: 2025012707|
2025/03/28 00:22:24:337|ASL|Extracted build number: 2025012408|
2025/03/28 00:22:24:337|ASL|Extracted build number: 2025012701|
2025/03/28 00:22:24:338|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:338|ASL|Extracted build number: 2025032503|
2025/03/28 00:22:24:338|ASL|Extracted build number: 2025012002|
2025/03/28 00:22:24:338|ASL|Extracted build number: 2025011001|
2025/03/28 00:22:24:338|ASL|Extracted build number: 2025031001|
2025/03/28 00:22:24:338|ASL|Extracted build number: 2025030301|
2025/03/28 00:22:24:338|ASL|Extracted build number: 2025012305|
2025/03/28 00:22:24:338|ASL|Extracted build number: 2025031004|
2025/03/28 00:22:24:338|ASL|Extracted build number: 2025031204|
2025/03/28 00:22:24:338|ASL|Extracted build number: 2025031801|
2025/03/28 00:22:24:338|ASL|Extracted build number: 2025012907|
2025/03/28 00:22:24:338|ASL|Extracted build number: 42810|
2025/03/28 00:22:24:339|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:339|ASL|Extracted build number: 2025012407|
2025/03/28 00:22:24:339|ASL|Extracted build number: 2025032604|
2025/03/28 00:22:24:339|ASL|Extracted build number: 2025012802|
2025/03/28 00:22:24:339|ASL|Extracted build number: 2025011403|
2025/03/28 00:22:24:339|ASL|Extracted build number: 2025022701|
2025/03/28 00:22:24:339|ASL|Extracted build number: 2025020213|
2025/03/28 00:22:24:339|ASL|Extracted build number: 2025021214|
2025/03/28 00:22:24:340|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:340|ASL|Extracted build number: 2025031501|
2025/03/28 00:22:24:340|ASL|Extracted build number: 2025011901|
2025/03/28 00:22:24:340|ASL|Extracted build number: 2025032701|
2025/03/28 00:22:24:340|ASL|Extracted build number: 2025030304|
2025/03/28 00:22:24:341|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:341|ASL|Extracted build number: 2025021219|
2025/03/28 00:22:24:341|ASL|Extracted build number: 2024101807|
2025/03/28 00:22:24:341|ASL|Extracted build number: 2025012206|
2025/03/28 00:22:24:341|ASL|Extracted build number: 2025012305|
2025/03/28 00:22:24:341|ASL|Extracted build number: 2025012105|
2025/03/28 00:22:24:341|ASL|Extracted build number: 42890|
2025/03/28 00:22:24:342|ASL|Extracted build number: 2025030303|
2025/03/28 00:22:24:342|ASL|Extracted build number: 2025012002|
2025/03/28 00:22:24:342|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:342|ASL|Extracted build number: 2025011802|
2025/03/28 00:22:24:342|ASL|Extracted build number: 2025013004|
2025/03/28 00:22:24:342|ASL|Extracted build number: 2025021901|
2025/03/28 00:22:24:342|ASL|Extracted build number: 2025012707|
2025/03/28 00:22:24:342|ASL|Extracted build number: 2025030307|
2025/03/28 00:22:24:342|ASL|Extracted build number: 2025012906|
2025/03/28 00:22:24:343|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:343|ASL|Extracted build number: 2025012703|
2025/03/28 00:22:24:343|ASL|Extracted build number: 2025020208|
2025/03/28 00:22:24:343|ASL|Extracted build number: 2025013109|
2025/03/28 00:22:24:343|ASL|Extracted build number: 2025020202|
2025/03/28 00:22:24:343|ASL|Extracted build number: 2025031105|
2025/03/28 00:22:24:343|ASL|Extracted build number: 2025012402|
2025/03/28 00:22:24:343|ASL|Extracted build number: 2025020217|
2025/03/28 00:22:24:344|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:344|ASL|Extracted build number: 2025010901|
2025/03/28 00:22:24:344|ASL|Extracted build number: 2025032402|
2025/03/28 00:22:24:344|ASL|Extracted build number: 2025012310|
2025/03/28 00:22:24:345|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:345|ASL|Extracted build number: 2025030708|
2025/03/28 00:22:24:345|ASL|Extracted build number: 2025012001|
2025/03/28 00:22:24:346|ASL|Extracted build number: 2025010801|
2025/03/28 00:22:24:346|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:346|ASL|Extracted build number: 2025012303|
2025/03/28 00:22:24:346|ASL|Extracted build number: 2025031104|
2025/03/28 00:22:24:346|ASL|Extracted build number: 2025012601|
2025/03/28 00:22:24:347|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:355|ASL|Extracted build number: 2025011303|
2025/03/28 00:22:24:355|ASL|Extracted build number: 2025012209|
2025/03/28 00:22:24:355|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:355|ASL|Extracted build number: 42850|
2025/03/28 00:22:24:355|ASL|Extracted build number: 2025032103|
2025/03/28 00:22:24:356|ASL|Extracted build number: 2025020209|
2025/03/28 00:22:24:356|ASL|Extracted build number: 2025030704|
2025/03/28 00:22:24:356|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:356|ASL|Extracted build number: 2025011601|
2025/03/28 00:22:24:356|ASL|Extracted build number: 42830|
2025/03/28 00:22:24:357|ASL|Extracted build number: 2025022104|
2025/03/28 00:22:24:357|ASL|Extracted build number: 2025022306|
2025/03/28 00:22:24:357|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:357|ASL|Extracted build number: 2025011101|
2025/03/28 00:22:24:357|ASL|Extracted build number: 2025012005|
2025/03/28 00:22:24:358|ASL|Extracted build number: 2025011402|
2025/03/28 00:22:24:358|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:358|ASL|Extracted build number: 2025020214|
2025/03/28 00:22:24:359|ASL|Extracted build number: 2025012604|
2025/03/28 00:22:24:359|ASL|Extracted build number: 2025022512|
2025/03/28 00:22:24:360|ASL|No numeric part found in the filename.|
2025/03/28 00:22:24:360|STORE|The store already exists in udefs|
2025/03/28 00:22:24:360|xw|the new store already exists btt_data_store.version_5_286_build_2025032702|
2025/03/28 00:22:24:427|migrate|fixing uuids2|
2025/03/28 00:22:24:531|LIC|idate 2021-12-18 11:00:38 +0000|
2025/03/28 00:22:24:533|ASL|sub 5 elapsed 0.267376 - prevke|
2025/03/28 00:22:24:533|INIT|FINISH PREVIOUSLYININIT|
2025/03/28 00:22:24:534|ASL|7 elapsed 0.323882|
2025/03/28 00:22:24:534|LIC|closing previous instance of BetterTouchTool relaunch|
2025/03/28 00:22:24:534|ASL|8 elapsed 0.324519|
2025/03/28 00:22:24:534|ASL|9 elapsed 0.324669|
2025/03/28 00:22:24:534|ASL|10 elapsed 0.324827|
2025/03/28 00:22:24:538|ASL|11 elapsed 0.327953|
2025/03/28 00:22:24:541|LIC|license appears to be valid|
2025/03/28 00:22:24:541|LIC|license dictionary {
    CheckoutName = my first name;
    Email = "my email";
    LicenseType = "paddle_lifetime";
    Licenses = 1;
    Name = "my full name";
    OrderID = my order ID;
    Product = BetterTouchTool;
    Signature = {length = 128, bytes = 0x8b279012 5175e99e a5475bea 76b1caea ... 96d91f52 0b0c248d };
    Timestamp = 1551018035;
    TransactionID = "29264544-chre3f3c91f69e8-2b1db903d9";
2025/03/28 00:22:24:541|LIC|systemdate 2019-02-24 14:20:35 +0000|
2025/03/28 00:22:24:541|LIC|using date 1551018035|
2025/03/28 00:22:24:542|LIC|license appears to be valid|
2025/03/28 00:22:24:542|LIC|license dictionary {
    Email = "my email";
    Licenses = 1;
    OrderID = my order id;
2025/03/28 00:22:24:542|LIC|systemdate 2019-02-24 14:20:35 +0000|
2025/03/28 00:22:24:542|lic|newest date 2019-02-24 14:20:35 +0000|
2025/03/28 00:22:24:542|lic|lict 29264544-chre3f3c91f69e8-2b1db903d9|
2025/03/28 00:22:24:547|lic|newest date 2019-02-24 14:20:35 +0000|
2025/03/28 00:22:24:547|lic|lict 29264544-chre3f3c91f69e8-2b1db903d9|
2025/03/28 00:22:24:547|LIC|License is valid for this version|
2025/03/28 00:22:24:548|ASL|12 elapsed 0.338162|
2025/03/28 00:22:24:548|ASL|disablign app nap|
2025/03/28 00:22:24:548|ASL|disabling app nap done|
2025/03/28 00:22:24:548|ASL|13 elapsed 0.338206|
2025/03/28 00:22:24:548|ASL|14 elapsed 0.338220|
2025/03/28 00:22:24:548|ASL|15 elapsed 0.338281|
2025/03/28 00:22:24:550|ASL|16 elapsed 0.340584|
2025/03/28 00:22:24:550|ASL|17 elapsed 0.340622|
2025/03/28 00:22:24:557|lic|newest date 2019-02-24 14:20:35 +0000|
2025/03/28 00:22:24:557|lic|lict 29264544-chre3f3c91f69e8-2b1db903d9|
2025/03/28 00:22:24:557|ASL|18 elapsed 0.347347|
2025/03/28 00:22:24:557|ASL|19 elapsed 0.347372|
2025/03/28 00:22:24:557|ASL|20 elapsed 0.347455|
2025/03/28 00:22:24:557|ASL|21 elapsed 0.347474|
2025/03/28 00:22:24:557|ASL|22 elapsed 0.347484|
2025/03/28 00:22:24:558|ASL|23 elapsed 0.348566|
2025/03/28 00:22:24:558|ASL|24 elapsed 0.348592|
2025/03/28 00:22:24:558|ASL|25 elapsed 0.348626|
2025/03/28 00:22:24:558|ASL|26 elapsed 0.348737|
2025/03/28 00:22:24:573|ASL|27 elapsed 0.363616|
2025/03/28 00:22:24:578|lic|newest date 2019-02-24 14:20:35 +0000|
2025/03/28 00:22:24:578|lic|lict 29264544-chre3f3c91f69e8-2b1db903d9|
2025/03/28 00:22:24:581|xw|is trusted|
2025/03/28 00:22:24:618|short|call sharedInstance4|
2025/03/28 00:22:24:685|ASL|The Mac is connected to AC power.|
2025/03/28 00:22:24:686|ASL|28 elapsed 0.476320|
2025/03/28 00:22:24:686|ASL|29 elapsed 0.476343|
2025/03/28 00:22:24:686|ASL|30 elapsed 0.476743|
2025/03/28 00:22:24:686|ASL|31 elapsed 0.476763|
2025/03/28 00:22:24:687|ASL|32 elapsed 0.477279|
2025/03/28 00:22:24:701|ASL|33 elapsed 0.491078|
2025/03/28 00:22:24:702|ASL|34 elapsed 0.492084|
2025/03/28 00:22:24:702|START|TB VISIBLE 0|
2025/03/28 00:22:24:702|START|TB FORCED HIDDEN 0|
2025/03/28 00:22:24:702|ASL|35 elapsed 0.492114|
2025/03/28 00:22:24:707|ASL|36 elapsed 0.497679|
2025/03/28 00:22:24:708|ASL|37 elapsed 0.497968|
2025/03/28 00:22:24:708|ASL|38 elapsed 0.497985|
2025/03/28 00:22:24:708|LAUNCH|DIDLaunch END frontmostApp: com.google.Chrome, touchpadMode 0, windowSnappingDisabled 0, singleFingerScrollingDisabled 0, mmScrollingUsed 0, tpScrollingUsed 0, tpPinchUsed 0, tpRotateUsed 0|
2025/03/28 00:22:24:708|ASL|39 elapsed 0.498025|
2025/03/28 00:22:24:708|ASL|40 elapsed 0.498043|
2025/03/28 00:22:24:724|ASL|keyboard added?|
2025/03/28 00:22:24:731|KEY|initialized for keyboard Apple Internal Keyboard / Trackpad|
2025/03/28 00:22:24:783|ASL|converted gesture to json in 0.000222|
2025/03/28 00:22:24:783|ASL|converted gesture to json in 0.000563|
2025/03/28 00:22:24:783|ASL|finished merging floating menus in 0.003628s|
2025/03/28 00:22:24:783|ASL|start reload 764839344.783269|
2025/03/28 00:22:24:783|ASL|finished merging floating menus in 0.000050s|
2025/03/28 00:22:24:783|ASL|start reload 764839344.783352|
2025/03/28 00:22:24:783|ASL|reset and reload?|
2025/03/28 00:22:24:783|ASL|reevaluate|
2025/03/28 00:22:24:783|M|mt_stop10|
2025/03/28 00:22:24:921|PERM|Can record screen 1|
2025/03/28 00:22:25:045|ASL|new xmlhttp request|
2025/03/28 00:22:25:267|ASL|+[IMKClient subclass]: chose IMKClient_Modern|
2025/03/28 00:22:25:483|ASL|new xmlhttp request|
2025/03/28 00:22:27:403|ASL|Hyper key used 0|
2025/03/28 00:22:27:468|BTT|mt device 0x0200000000000033,0x6c - 108 - internal 1 - force 1|
2025/03/28 00:22:27:469|M|register touchbar mbp trackpad|
2025/03/28 00:22:27:469|STDEV|6c|
2025/03/28 00:22:27:522|ASL|saving|
2025/03/28 00:22:27:631|short|eventtap success|
2025/03/28 00:22:27:654|ASL|finished merging floating menus in 0.002613s|
2025/03/28 00:22:27:654|ASL|start reload 764839347.653979|
2025/03/28 00:22:27:713|ASL|creating new atc timer 1.000000|
2025/03/28 00:22:40:863|SYS|Running on macOS: 15.3.2|
2025/03/28 00:22:40:863|SYS|BTT Version: 5.286|
2025/03/28 00:22:40:863|SYS|Device: MacBookPro18,4|
2025/03/28 00:22:40:895|usage|loading todays usage|
2025/03/28 00:22:40:895|ASL|0 elapsed 0.040108|
2025/03/28 00:22:40:895|LAUNCH|DIDLaunch START NSConcreteNotification 0x600002c89760 {name = NSApplicationDidFinishLaunchingNotification; object = <BTTApplication: 0x1587089e0>; userInfo = {
    NSApplicationLaunchIsDefaultLaunchKey = 1;
2025/03/28 00:22:40:919|ASL|1 elapsed 0.064365|
2025/03/28 00:22:40:919|ASL|2 elapsed 0.064398|
2025/03/28 00:22:40:919|ASL|3 elapsed 0.064530|
2025/03/28 00:22:40:920|ASL|4 elapsed 0.064613|
2025/03/28 00:22:40:921|ASL|5 elapsed 0.066206|
2025/03/28 00:22:40:921|ASL|6 elapsed 0.066257|
2025/03/28 00:22:40:921|INIT|START PREVIOUSLYININIT|
2025/03/28 00:22:40:921|ASL|sub 0 elapsed 0.000000 - prev|
2025/03/28 00:22:40:934|ASL|sub 1 elapsed 0.012346 - prev|
2025/03/28 00:22:40:934|ASL|sub 2 elapsed 0.012769 - prev|
2025/03/28 00:22:40:934|ASL|sub 3 elapsed 0.013111 - prev|
2025/03/28 00:22:40:935|ASL|sub 4 elapsed 0.013941 - prevk|
2025/03/28 00:22:40:935|short|init|
2025/03/28 00:22:40:975|KEY|initialized for keyboard Apple Internal Keyboard / Trackpad|
2025/03/28 00:22:40:977|ASL|No numeric part found in the filename.|
2025/03/28 00:22:40:977|ASL|Extracted build number: 2025012602|
2025/03/28 00:22:40:977|ASL|Extracted build number: 2025032702|
2025/03/28 00:22:40:977|ASL|Extracted build number: 2025020219|
2025/03/28 00:22:40:977|ASL|Extracted build number: 2025032104|
2025/03/28 00:22:40:978|ASL|No numeric part found in the filename.|
2025/03/28 00:22:40:978|ASL|Extracted build number: 2024122702|
2025/03/28 00:22:40:978|ASL|Extracted build number: 2025012104|
2025/03/28 00:22:40:978|ASL|Extracted build number: 2025022103|
2025/03/28 00:22:40:979|ASL|Extracted build number: 2025022002|
2025/03/28 00:22:40:979|ASL|Extracted build number: 2025020212|
2025/03/28 00:22:40:979|ASL|Extracted build number: 2025011201|
2025/03/28 00:22:40:979|ASL|Extracted build number: 2025021215|
2025/03/28 00:22:40:979|ASL|Extracted build number: 2025013107|
2025/03/28 00:22:40:979|ASL|No numeric part found in the filename.|
2025/03/28 00:22:40:979|ASL|Extracted build number: 2025012311|
2025/03/28 00:22:40:979|ASL|Extracted build number: 2025031103|
2025/03/28 00:22:40:979|ASL|Extracted build number: 2025021703|
2025/03/28 00:22:40:979|ASL|Extracted build number: 2025012803|
2025/03/28 00:22:40:981|ASL|No numeric part found in the filename.|
2025/03/28 00:22:40:981|ASL|Extracted build number: 2025030705|
2025/03/28 00:22:40:982|ASL|Extracted build number: 2025022804|
2025/03/28 00:22:40:982|ASL|Extracted build number: 2025012908|
2025/03/28 00:22:40:982|ASL|No numeric part found in the filename.|
2025/03/28 00:22:40:982|ASL|Extracted build number: 2025011404|
2025/03/28 00:22:40:982|ASL|Extracted build number: 2025011301|
2025/03/28 00:22:40:982|ASL|Extracted build number: 2025011004|
2025/03/28 00:22:40:982|ASL|Extracted build number: 2025021902|
2025/03/28 00:22:40:982|ASL|Extracted build number: 2025030306|
2025/03/28 00:22:40:982|ASL|Extracted build number: 2025020204|
2025/03/28 00:22:40:983|ASL|No numeric part found in the filename.|
2025/03/28 00:22:40:983|ASL|Extracted build number: 2025030501|
2025/03/28 00:22:40:983|ASL|Extracted build number: 2025010701|
2025/03/28 00:22:40:983|ASL|Extracted build number: 2025011801|
2025/03/28 00:22:40:983|ASL|Extracted build number: 2025021218|
2025/03/28 00:22:40:983|ASL|Extracted build number: 2025012707|
2025/03/28 00:22:40:984|ASL|Extracted build number: 2025012408|
2025/03/28 00:22:40:984|ASL|Extracted build number: 2025012701|
2025/03/28 00:22:40:984|ASL|No numeric part found in the filename.|
2025/03/28 00:22:40:984|ASL|Extracted build number: 2025032503|
2025/03/28 00:22:40:984|ASL|Extracted build number: 2025012002|
It's difficult to type, as in, there appears to be a lag and sometimes omission of the characters I type in my keystrokes. I have to type very slowly.
Text selection is acting strangely. My clipboard is acting strangely. And my cursor sometimes moves unexpectedly.
these are normal logs, are there any crashlogs in the macOS console app? Best quit BTT completely if it is trying to restart
killall BetterTouchTool && killall BTTRelaunch
These are indeed crash logs from the Console app. Here's an example of one:
Translated Report (Full Report Below)
Process:               BetterTouchTool [63526]
Path:                  /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
Identifier:            com.hegenberg.BetterTouchTool
Version:               5.286 (2025032702)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2025-03-28 00:14:12.8714 -0700
OS Version:            macOS 15.3.2 (24D81)
Report Version:        12
Anonymous UUID:        F83147C6-3426-A747-8699-A3E379B66F5F
Sleep/Wake UUID:       15A556B3-AF6C-4B27-80AA-DE014AC7DF4F
Time Awake Since Boot: 170000 seconds
Time Since Wake:       9150 seconds
System Integrity Protection: enabled
Crashed Thread:        0
Exception Type:        EXC_BREAKPOINT (SIGTRAP)
Exception Codes:       0x0000000000000001, 0x000000010135123c
Termination Reason:    Namespace SIGNAL, Code 5 Trace/BPT trap: 5
Terminating Process:   exc handler [63526]
Thread 0 Crashed:
0   BetterTouchTool               	       0x10135123c 0x1008c4000 + 11063868
1   BetterTouchTool               	       0x100e822e8 0x1008c4000 + 6021864
2   BetterTouchTool               	       0x100e824f0 0x1008c4000 + 6022384
3   BetterTouchTool               	       0x100a92da4 0x1008c4000 + 1895844
4   BetterTouchTool               	       0x100a8f7a4 0x1008c4000 + 1882020
5   BetterTouchTool               	       0x100b28e8c 0x1008c4000 + 2510476
6   BetterTouchTool               	       0x100b31be4 0x1008c4000 + 2546660
7   BetterTouchTool               	       0x1008d1dac 0x1008c4000 + 56748
8   BetterTouchTool               	       0x100b30ce4 0x1008c4000 + 2542820
9   BetterTouchTool               	       0x100b2f8b4 0x1008c4000 + 2537652
10  BetterTouchTool               	       0x100b255d8 0x1008c4000 + 2495960
11  CoreFoundation                	       0x186ed5370 0x186e63000 + 467824
12  CoreFoundation                	       0x186f6620c 0x186e63000 + 1061388
13  CoreFoundation                	       0x186f66154 0x186e63000 + 1061204
14  CoreFoundation                	       0x186ea3fac 0x186e63000 + 266156
15  Foundation                    	       0x18805e6b8 0x188055000 + 38584
16  AppKit                        	       0x18abf0240 0x18aa1b000 + 1921600
17  LaunchServices                	       0x18737af90 0x187358000 + 143248
18  CoreFoundation                	       0x186ee0430 0x186e63000 + 513072
19  CoreFoundation                	       0x186ee0340 0x186e63000 + 512832
20  CoreFoundation                	       0x186edf770 0x186e63000 + 509808
21  CoreFoundation                	       0x186ede734 0x186e63000 + 505652
22  HIToolbox                     	       0x19244d530 0x192342000 + 1094960
23  HIToolbox                     	       0x192453348 0x192342000 + 1119048
24  HIToolbox                     	       0x192453508 0x192342000 + 1119496
25  AppKit                        	       0x18aa56848 0x18aa1b000 + 243784
26  AppKit                        	       0x18b3bcc24 0x18aa1b000 + 10099748
27  AppKit                        	       0x18aa49874 0x18aa1b000 + 190580
28  AppKit                        	       0x18aa20068 0x18aa1b000 + 20584
29  dyld                          	       0x186a78274 0x186a72000 + 25204
Thread 1:
0   libsystem_pthread.dylib       	       0x186df30e8 0x186df1000 + 8424
Thread 2:
Thread 3:
0   libsystem_kernel.dylib        	       0x186db6f54 0x186db6000 + 3924
1   libsystem_kernel.dylib        	       0x186dbfaf8 0x186db6000 + 39672
2   libsystem_kernel.dylib        	       0x186db729c 0x186db6000 + 4764
3   CoreFoundation                	       0x186ee0a4c 0x186e63000 + 514636
4   CoreFoundation                	       0x186edf2ac 0x186e63000 + 508588
5   CoreFoundation                	       0x186ede734 0x186e63000 + 505652
6   AE                            	       0x18e4b09f4 0x18e473000 + 252404
7   AE                            	       0x18e48ca64 0x18e473000 + 105060
8   ScriptingBridge               	       0x1d10606c8 -[SBAppContext sendEvent:error:] + 80
9   ScriptingBridge               	       0x1d1059b44 -[SBObject sendEvent:id:parameters:] + 236
10  ScriptingBridge               	       0x1d1062450 -[SBPropertyGetterThunk invoke:] + 120
11  CoreFoundation                	       0x186ebf5d4 0x186e63000 + 378324
12  CoreFoundation                	       0x186ebf150 0x186e63000 + 377168
13  BetterTouchTool               	       0x1009af8ac 0x1008c4000 + 964780
14  libdispatch.dylib             	       0x186c43854 0x186c41000 + 10324
15  libdispatch.dylib             	       0x186c455b4 0x186c41000 + 17844
16  libdispatch.dylib             	       0x186c576a0 0x186c41000 + 91808
17  libdispatch.dylib             	       0x186c57cd8 0x186c41000 + 93400
18  libsystem_pthread.dylib       	       0x186df439c 0x186df1000 + 13212
19  libsystem_pthread.dylib       	       0x186df30f0 0x186df1000 + 8432
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:: com.apple.NSEventThread
6   AppKit                        	       0x18ab7b278 0x18aa1b000 + 1442424
7   libsystem_pthread.dylib       	       0x186df82e4 0x186df1000 + 29412
8   libsystem_pthread.dylib       	       0x186df30fc 0x186df1000 + 8444
Thread 15:
Thread 16:
Thread 17:
Thread 18:: JavaScriptCore libpas scavenger
0   libsystem_kernel.dylib        	       0x186dba6ec 0x186db6000 + 18156
1   JavaScriptCore                	       0x1a6568ae4 scavenger_thread_main + 1524
2   libsystem_pthread.dylib       	       0x186df82e4 0x186df1000 + 29412
3   libsystem_pthread.dylib       	       0x186df30fc 0x186df1000 + 8444
Thread 19:: com.apple.NSURLConnectionLoader
6   CFNetwork                     	       0x18c7e669c 0x18c591000 + 2447004
7   Foundation                    	       0x1880a9444 0x188055000 + 345156
8   libsystem_pthread.dylib       	       0x186df82e4 0x186df1000 + 29412
9   libsystem_pthread.dylib       	       0x186df30fc 0x186df1000 + 8444
Thread 0 crashed with ARM Thread State (64-bit):
    x0: 0x0000000000000000   x1: 0x0000000000000000   x2: 0x00000001013511a0   x3: 0x00006000021dfa98
    x4: 0x0000000000000000   x5: 0x000000000000001d   x6: 0x0000000000000000   x7: 0x0000000000000000
    x8: 0x0000000000000000   x9: 0x0000000000000000  x10: 0x80000002ffffffff  x11: 0x000000000009f5a0
   x12: 0x0000000138703fa0  x13: 0x000000000000001e  x14: 0x0000000138700000  x15: 0x000000000000ffff
   x16: 0x0000000197f68ac0  x17: 0x23eb0001f07662b0  x18: 0x0000000000000000  x19: 0x0000000000000000
   x20: 0x00006000021dfa70  x21: 0x00000001f0cef608  x22: 0x0000000000000000  x23: 0x0000600000230c20
   x24: 0x0000000000000008  x25: 0x00006000021dfa20  x26: 0x0000600000c30c00  x27: 0x0000000000000000
   x28: 0x000060000181abc0   fp: 0x000000016f538ac0   lr: 0x00000001013511a0
    sp: 0x000000016f538a50   pc: 0x000000010135123c cpsr: 0x60001000
   far: 0x0000000000000000  esr: 0xf2000001 (Breakpoint) brk 1
Binary Images:
       0x1008c4000 -        0x101b8ffff com.hegenberg.BetterTouchTool (5.286) <c97a617e-7ba4-3f42-bb0b-04e4fd9a8701> /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
       0x102180000 -        0x1021cffff com.mixedinkey.MIKMIDI (1.5) <16ddf028-19de-3847-bbd4-8c164b405d1f> /Applications/BetterTouchTool.app/Contents/Frameworks/MIKMIDI.framework/Versions/A/MIKMIDI
       0x102030000 -        0x102083fff com.ridiculousfish.HexFiend-Framework (2.18.1) <ce31ba42-f6b6-3617-b5d5-ddd35f9414fb> /Applications/BetterTouchTool.app/Contents/Frameworks/HexFiend.framework/Versions/A/HexFiend
       0x10213c000 -        0x102147fff net.wafflesoftware.ShortcutRecorder.framework.Leopard (*) <1f28ebb9-986a-3e5a-b15c-01183c53a265> /Applications/BetterTouchTool.app/Contents/Frameworks/ShortcutRecorder.framework/Versions/A/ShortcutRecorder
       0x102410000 -        0x10248ffff com.mentalfaculty.ensembles (2.9.1) <36a6c99c-16d4-3f47-8040-37cdc7663a02> /Applications/BetterTouchTool.app/Contents/Frameworks/Ensembles.framework/Versions/A/Ensembles
       0x1024dc000 -        0x102533fff org.sparkle-project.Sparkle (2.2.1) <998f01d4-1e73-3cec-a0c6-5a49be01dbf5> /Applications/BetterTouchTool.app/Contents/Frameworks/Sparkle.framework/Versions/B/Sparkle
       0x102120000 -        0x102123fff com.hegenberg.BTTPluginSupport (1.0) <8544739d-8d4d-319f-bd3f-e505148b2242> /Applications/BetterTouchTool.app/Contents/Frameworks/BTTPluginSupport.framework/Versions/A/BTTPluginSupport
       0x1020f0000 -        0x1020f3fff com.potionfactory.LetsMove (1.25) <4cccd167-7048-39ff-a5c4-594f5fa5e57a> /Applications/BetterTouchTool.app/Contents/Frameworks/LetsMove.framework/Versions/A/LetsMove
       0x10ece4000 -        0x10eceffff libobjc-trampolines.dylib (*) <3d687e9b-e092-3632-bc1d-74b19d492de0> /usr/lib/libobjc-trampolines.dylib
       0x11013c000 -        0x110153fff com.apple.iokit.IOHIDLib (2.0.0) <a8fe4691-d173-3b0b-8c08-0e0d938b0208> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
       0x1056a4000 -        0x1056c3fff com.apple.security.csparser (3.0) <fb85321b-0fa8-3ace-941c-abef6c37ff36> /System/Library/Frameworks/Security.framework/Versions/A/PlugIns/csparser.bundle/Contents/MacOS/csparser
       0x1058e8000 -        0x1058f3fff com.apple.security.ldapdl (4.0) <21ff6513-5fa3-3f13-b700-a9b58f85fbcf> /System/Library/Security/ldapdl.bundle/Contents/MacOS/ldapdl
       0x12c1a4000 -        0x12c847fff com.apple.AGXMetalG13X (324.6) <d03677d4-c896-3fd7-88c0-abed05133e06> /System/Library/Extensions/AGXMetalG13X.bundle/Contents/MacOS/AGXMetalG13X
       0x186e63000 -        0x187357fff com.apple.CoreFoundation (6.9) <190e6a36-fcaa-3ea3-94bb-7009c44653da> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
       0x188055000 -        0x188e9cfff com.apple.Foundation (6.9) <16d282d0-8b48-3e76-8036-fcb45dece518> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
       0x18aa1b000 -        0x18be57fff com.apple.AppKit (6.9) <b88a44c1-d617-33dc-90ed-b6ab417c428e> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
       0x187358000 -        0x18763ffff com.apple.LaunchServices (1141.1) <0bd79215-03e1-3d88-8104-97d48bf358af> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
       0x192342000 -        0x192649fff com.apple.HIToolbox (2.1.1) <950f1236-acaf-379d-819f-6c6b0b5deabd> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
       0x186a72000 -        0x186af3f3f dyld (*) <398a133c-9bcb-317f-a064-a40d3cea3c0f> /usr/lib/dyld
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
       0x197b99000 -        0x19813cfff libswiftCore.dylib (*) <a0ebe73e-3b7b-329e-985c-e884aba916df> /usr/lib/swift/libswiftCore.dylib
       0x186df1000 -        0x186dfdfff libsystem_pthread.dylib (*) <642faf7a-874e-37e6-8aba-2b0cc09a3025> /usr/lib/system/libsystem_pthread.dylib
       0x186db6000 -        0x186df0ff7 libsystem_kernel.dylib (*) <eee9d0d3-dffc-37cb-9ced-b27cd0286d8c> /usr/lib/system/libsystem_kernel.dylib
       0x18e473000 -        0x18e4e7ff7 com.apple.AE (944) <09e72a53-8b7e-3365-987b-3b6ca4f73672> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
       0x1d1055000 -        0x1d106cfff com.apple.ScriptingBridge (1.4) <74ac1f24-541d-3884-a0f7-ea1d89435393> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
       0x186c41000 -        0x186c87fff libdispatch.dylib (*) <5576e4fd-aad2-3608-8c8f-4eec421236f9> /usr/lib/system/libdispatch.dylib
       0x1a4f29000 -        0x1a6756fbf com.apple.JavaScriptCore (20620) <49a0e786-bb6d-35af-9d6e-f873c2746c66> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
       0x18c591000 -        0x18c959fff com.apple.CFNetwork (1.0) <446389be-e9e5-34d6-b055-567fab324e8b> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 4
    thread_create: 0
    thread_set_state: 96
VM Region Summary:
ReadOnly portion of Libraries: Total=1.6G resident=0K(0%) swapped_out_or_unallocated=1.6G(100%)
Writable regions: Total=6.7G written=1237K(0%) resident=1237K(0%) swapped_out=0K(0%) unallocated=6.7G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               128K        1
Activity Tracing                   256K        1
CG image                          4784K       64
ColorSync                          544K       26
CoreData                            96K        2
CoreData Object IDs               4112K        2
CoreGraphics                        16K        1
CoreGraphics (reserved)             16K        1         reserved VM address space (unallocated)
Foundation                       303.7M      300
IOAccelerator                       48K        1
IOKit                               32K        2
Image IO                         303.7M      598
Kernel Alloc Once                   32K        1
MALLOC                             1.9G       80
MALLOC guard page                  384K       24
SQLite page cache                 9088K       71
STACK GUARD                       56.3M       20
Stack                             18.1M       20
VM_ALLOCATE                      128.1M        9
VM_ALLOCATE (reserved)             3.9G        1         reserved VM address space (unallocated)
WebKit Malloc                    160.1M        3
WebKit Malloc (reserved)          32.0M        1         reserved VM address space (unallocated)
__AUTH                            5306K      683
__AUTH_CONST                      71.1M      936
__CTF                               824        1
__DATA                            27.0M      930
__DATA_CONST                      25.3M      957
__DATA_DIRTY                      2752K      345
__FONT_DATA                        2352        1
__INFO_FILTER                         8        1
__LINKEDIT                       610.4M       14
__OBJC_RW                         2374K        1
__TEXT                             1.0G      980
__TPRO_CONST                       272K        2
libnetwork                         128K        8
mapped file                      235.2M       41
owned unmapped memory              240K        1
page table in kernel              1237K        1
shared memory                     1456K       17
TOTAL                              8.7G     6148
TOTAL, minus reserved VM space     4.8G     6148
Full Report
{"app_name":"BetterTouchTool","timestamp":"2025-03-28 00:14:13.00 -0700","app_version":"5.286","slice_uuid":"c97a617e-7ba4-3f42-bb0b-04e4fd9a8701","build_version":"2025032702","platform":1,"bundleID":"com.hegenberg.BetterTouchTool","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 15.3.2 (24D81)","roots_installed":0,"name":"BetterTouchTool","incident_id":"04E682CA-905C-4CDD-94CD-D74CE1E4FEFC"}
  "uptime" : 170000,
  "procRole" : "Default",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro18,4",
  "coalitionID" : 60201,
  "osVersion" : {
    "train" : "macOS 15.3.2",
    "build" : "24D81",
    "releaseType" : "User"
  "captureTime" : "2025-03-28 00:14:12.8714 -0700",
  "codeSigningMonitor" : 1,
  "incident" : "04E682CA-905C-4CDD-94CD-D74CE1E4FEFC",
  "pid" : 63526,
  "translated" : false,
  "cpuType" : "ARM-64",
  "roots_installed" : 0,
  "bug_type" : "309",
  "procLaunch" : "2025-03-28 00:14:09.2011 -0700",
  "procStartAbsTime" : 4116779990276,
  "procExitAbsTime" : 4116867707573,
  "procName" : "BetterTouchTool",
  "procPath" : "\/Applications\/BetterTouchTool.app\/Contents\/MacOS\/BetterTouchTool",
  "bundleInfo" : {"CFBundleShortVersionString":"5.286","CFBundleVersion":"2025032702","CFBundleIdentifier":"com.hegenberg.BetterTouchTool"},
  "storeInfo" : {"deviceIdentifierForVendor":"49C63CF2-9321-50F0-A160-5084974E563C","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.hegenberg.BetterTouchTool",
  "crashReporterKey" : "F83147C6-3426-A747-8699-A3E379B66F5F",
  "codeSigningID" : "com.hegenberg.BetterTouchTool",
  "codeSigningTeamID" : "DAFVSXZ82P",
  "codeSigningFlags" : 570495745,
  "codeSigningValidationCategory" : 6,
  "codeSigningTrustLevel" : 4294967295,
  "instructionByteStream" : {"beforePC":"4AMTquEDFaokpQ+U4AMVquKrD5SAGkD5gPz\/tSAAINR9qQ+UIAAg1A==","atPC":"IAAg1CAAINQgACDU\/Xu\/qf0DAJGAGkD5IAEAtB6lD5SAGkD5AAEAtA=="},
  "bootSessionUUID" : "CF235252-19A1-4918-BF59-956D3056F22E",
  "wakeTime" : 9150,
  "sleepWakeUUID" : "15A556B3-AF6C-4B27-80AA-DE014AC7DF4F",
  "sip" : "enabled",
  "exception" : {"codes":"0x0000000000000001, 0x000000010135123c","rawCodes":[1,4315222588],"type":"EXC_BREAKPOINT","signal":"SIGTRAP"},
  "termination" : {"flags":0,"code":5,"namespace":"SIGNAL","indicator":"Trace\/BPT trap: 5","byProc":"exc handler","byPid":63526},
  "os_fault" : {"process":"BetterTouchTool"},
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":96,"task_for_pid":4},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":17227322,"threadState":{"x":[{"value":0},{"value":0},{"value":4315222432},{"value":105553151785624},{"value":0},{"value":29},{"value":0},{"value":0},{"value":0},{"value":0},{"value":9223372049739677695},{"value":652704},{"value":5241847712},{"value":30},{"value":5241831424},{"value":65535},{"value":6844484288},{"value":2588162419183739568},{"value":0},{"value":0},{"value":105553151785584},{"value":8335062536},{"value":0},{"value":105553118563360},{"value":8},{"value":105553151785504},{"value":105553129049088},{"value":0},{"value":105553141541824}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4315222432},"cpsr":{"value":1610616832},"fp":{"value":6162713280},"sp":{"value":6162713168},"esr":{"value":4060086273,"description":"(Breakpoint) brk 1"},"pc":{"value":4315222588,"matchesCrashFrame":1},"far":{"value":0}},"frames":[{"imageOffset":11063868,"imageIndex":0},{"imageOffset":6021864,"imageIndex":0},{"imageOffset":6022384,"imageIndex":0},{"imageOffset":1895844,"imageIndex":0},{"imageOffset":1882020,"imageIndex":0},{"imageOffset":2510476,"imageIndex":0},{"imageOffset":2546660,"imageIndex":0},{"imageOffset":56748,"imageIndex":0},{"imageOffset":2542820,"imageIndex":0},{"imageOffset":2537652,"imageIndex":0},{"imageOffset":2495960,"imageIndex":0},{"imageOffset":467824,"imageIndex":13},{"imageOffset":1061388,"imageIndex":13},{"imageOffset":1061204,"imageIndex":13},{"imageOffset":266156,"imageIndex":13},{"imageOffset":38584,"imageIndex":14},{"imageOffset":1921600,"imageIndex":15},{"imageOffset":143248,"imageIndex":16},{"imageOffset":513072,"imageIndex":13},{"imageOffset":512832,"imageIndex":13},{"imageOffset":509808,"imageIndex":13},{"imageOffset":505652,"imageIndex":13},{"imageOffset":1094960,"imageIndex":17},{"imageOffset":1119048,"imageIndex":17},{"imageOffset":1119496,"imageIndex":17},{"imageOffset":243784,"imageIndex":15},{"imageOffset":10099748,"imageIndex":15},{"imageOffset":190580,"imageIndex":15},{"imageOffset":20584,"imageIndex":15},{"imageOffset":25204,"imageIndex":18}]},{"id":17227406,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6163279872},{"value":5891},{"value":6162743296},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6163279872},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227407,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6163853312},{"value":5379},{"value":6163316736},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6163853312},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227547,"frames":[{"imageOffset":3924,"imageIndex":22},{"imageOffset":39672,"imageIndex":22},{"imageOffset":4764,"imageIndex":22},{"imageOffset":514636,"imageIndex":13},{"imageOffset":508588,"imageIndex":13},{"imageOffset":505652,"imageIndex":13},{"imageOffset":252404,"imageIndex":23},{"imageOffset":105060,"imageIndex":23},{"imageOffset":46792,"symbol":"-[SBAppContext sendEvent:error:]","symbolLocation":80,"imageIndex":24},{"imageOffset":19268,"symbol":"-[SBObject sendEvent:id:parameters:]","symbolLocation":236,"imageIndex":24},{"imageOffset":54352,"symbol":"-[SBPropertyGetterThunk invoke:]","symbolLocation":120,"imageIndex":24},{"imageOffset":378324,"imageIndex":13},{"imageOffset":377168,"imageIndex":13},{"imageOffset":964780,"imageIndex":0},{"imageOffset":10324,"imageIndex":25},{"imageOffset":17844,"imageIndex":25},{"imageOffset":91808,"imageIndex":25},{"imageOffset":93400,"imageIndex":25},{"imageOffset":13212,"imageIndex":21},{"imageOffset":8432,"imageIndex":21}],"threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":155044024418304},{"value":0},{"value":155044024418304},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":36099},{"value":1024},{"value":0},{"value":18446744073709551569},{"value":8470027768},{"value":0},{"value":4294967295},{"value":2},{"value":155044024418304},{"value":0},{"value":155044024418304},{"value":6164420552},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6557570564},"cpsr":{"value":4096},"fp":{"value":6164420400},"sp":{"value":6164420320},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557495124},"far":{"value":0}}},{"id":17227551,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6165000192},{"value":32523},{"value":6164463616},{"value":0},{"value":409603},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6165000192},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227569,"frames":[{"imageOffset":3924,"imageIndex":22},{"imageOffset":39672,"imageIndex":22},{"imageOffset":4764,"imageIndex":22},{"imageOffset":514636,"imageIndex":13},{"imageOffset":508588,"imageIndex":13},{"imageOffset":505652,"imageIndex":13},{"imageOffset":252404,"imageIndex":23},{"imageOffset":105060,"imageIndex":23},{"imageOffset":46792,"symbol":"-[SBAppContext sendEvent:error:]","symbolLocation":80,"imageIndex":24},{"imageOffset":19268,"symbol":"-[SBObject sendEvent:id:parameters:]","symbolLocation":236,"imageIndex":24},{"imageOffset":54352,"symbol":"-[SBPropertyGetterThunk invoke:]","symbolLocation":120,"imageIndex":24},{"imageOffset":378324,"imageIndex":13},{"imageOffset":377168,"imageIndex":13},{"imageOffset":964780,"imageIndex":0},{"imageOffset":10324,"imageIndex":25},{"imageOffset":17844,"imageIndex":25},{"imageOffset":91808,"imageIndex":25},{"imageOffset":93400,"imageIndex":25},{"imageOffset":13212,"imageIndex":21},{"imageOffset":8432,"imageIndex":21}],"threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":239706419757056},{"value":0},{"value":239706419757056},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":55811},{"value":1280},{"value":0},{"value":18446744073709551569},{"value":8470027768},{"value":0},{"value":4294967295},{"value":2},{"value":239706419757056},{"value":0},{"value":239706419757056},{"value":6165567432},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6557570564},"cpsr":{"value":4096},"fp":{"value":6165567280},"sp":{"value":6165567200},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557495124},"far":{"value":0}}},{"id":17227570,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6166147072},{"value":46339},{"value":6165610496},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6166147072},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227571,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6166720512},{"value":46595},{"value":6166183936},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6166720512},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227878,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6167293952},{"value":53511},{"value":6166757376},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6167293952},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227897,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6167867392},{"value":75527},{"value":6167330816},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6167867392},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227898,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6168440832},{"value":75271},{"value":6167904256},{"value":0},{"value":409603},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6168440832},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227899,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6169014272},{"value":75019},{"value":6168477696},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6169014272},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227900,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6169587712},{"value":78855},{"value":6169051136},{"value":0},{"value":409603},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6169587712},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227901,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6170161152},{"value":76547},{"value":6169624576},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6170161152},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227913,"name":"com.apple.NSEventThread","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":201240692654080},{"value":0},{"value":201240692654080},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":46855},{"value":0},{"value":0},{"value":18446744073709551569},{"value":8470027768},{"value":0},{"value":4294967295},{"value":2},{"value":201240692654080},{"value":0},{"value":201240692654080},{"value":6170730600},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6557570564},"cpsr":{"value":4096},"fp":{"value":6170730448},"sp":{"value":6170730368},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557495124},"far":{"value":0}},"frames":[{"imageOffset":3924,"imageIndex":22},{"imageOffset":39672,"imageIndex":22},{"imageOffset":4764,"imageIndex":22},{"imageOffset":514636,"imageIndex":13},{"imageOffset":508588,"imageIndex":13},{"imageOffset":505652,"imageIndex":13},{"imageOffset":1442424,"imageIndex":15},{"imageOffset":29412,"imageIndex":21},{"imageOffset":8444,"imageIndex":21}]},{"id":17227932,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6171308032},{"value":77827},{"value":6170771456},{"value":0},{"value":409603},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6171308032},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227933,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6172454912},{"value":76803},{"value":6171918336},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6172454912},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227934,"frames":[{"imageOffset":8424,"imageIndex":21}],"threadState":{"x":[{"value":6171881472},{"value":0},{"value":6171344896},{"value":0},{"value":278532},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6171881472},"esr":{"value":0,"description":" Address size fault"},"pc":{"value":6557741288},"far":{"value":0}}},{"id":17227935,"name":"JavaScriptCore libpas scavenger","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":160},{"value":9},{"value":999999088},{"value":6173027992},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8470045304},{"value":0},{"value":13153396992},{"value":13153397056},{"value":6173028576},{"value":999999088},{"value":9},{"value":0},{"value":4353},{"value":4608},{"value":6173028576},{"value":8298790912,"symbolLocation":1312,"symbol":"_MergedGlobals"}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6557763732},"cpsr":{"value":1610616832},"fp":{"value":6173028112},"sp":{"value":6173027968},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557509356},"far":{"value":0}},"frames":[{"imageOffset":18156,"imageIndex":22},{"imageOffset":23329508,"symbol":"scavenger_thread_main","symbolLocation":1524,"imageIndex":26},{"imageOffset":29412,"imageIndex":21},{"imageOffset":8444,"imageIndex":21}]},{"id":17227941,"name":"com.apple.NSURLConnectionLoader","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":387040977879040},{"value":0},{"value":387040977879040},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":90115},{"value":512},{"value":0},{"value":18446744073709551569},{"value":8470027768},{"value":0},{"value":4294967295},{"value":2},{"value":387040977879040},{"value":0},{"value":387040977879040},{"value":6173596984},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6557570564},"cpsr":{"value":4096},"fp":{"value":6173596832},"sp":{"value":6173596752},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6557495124},"far":{"value":0}},"frames":[{"imageOffset":3924,"imageIndex":22},{"imageOffset":39672,"imageIndex":22},{"imageOffset":4764,"imageIndex":22},{"imageOffset":514636,"imageIndex":13},{"imageOffset":508588,"imageIndex":13},{"imageOffset":505652,"imageIndex":13},{"imageOffset":2447004,"imageIndex":27},{"imageOffset":345156,"imageIndex":14},{"imageOffset":29412,"imageIndex":21},{"imageOffset":8444,"imageIndex":21}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64",
    "base" : 4304158720,
    "CFBundleShortVersionString" : "5.286",
    "CFBundleIdentifier" : "com.hegenberg.BetterTouchTool",
    "size" : 19709952,
    "uuid" : "c97a617e-7ba4-3f42-bb0b-04e4fd9a8701",
    "path" : "\/Applications\/BetterTouchTool.app\/Contents\/MacOS\/BetterTouchTool",
    "name" : "BetterTouchTool",
    "CFBundleVersion" : "2025032702"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4330094592,
    "CFBundleShortVersionString" : "1.5",
    "CFBundleIdentifier" : "com.mixedinkey.MIKMIDI",
    "size" : 327680,
    "uuid" : "16ddf028-19de-3847-bbd4-8c164b405d1f",
    "path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/MIKMIDI.framework\/Versions\/A\/MIKMIDI",
    "name" : "MIKMIDI",
    "CFBundleVersion" : "877"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4328718336,
    "CFBundleShortVersionString" : "2.18.1",
    "CFBundleIdentifier" : "com.ridiculousfish.HexFiend-Framework",
    "size" : 344064,
    "uuid" : "ce31ba42-f6b6-3617-b5d5-ddd35f9414fb",
    "path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/HexFiend.framework\/Versions\/A\/HexFiend",
    "name" : "HexFiend",
    "CFBundleVersion" : "200"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4329816064,
    "CFBundleIdentifier" : "net.wafflesoftware.ShortcutRecorder.framework.Leopard",
    "size" : 49152,
    "uuid" : "1f28ebb9-986a-3e5a-b15c-01183c53a265",
    "path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/ShortcutRecorder.framework\/Versions\/A\/ShortcutRecorder",
    "name" : "ShortcutRecorder",
    "CFBundleVersion" : "1.0"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4332781568,
    "CFBundleShortVersionString" : "2.9.1",
    "CFBundleIdentifier" : "com.mentalfaculty.ensembles",
    "size" : 524288,
    "uuid" : "36a6c99c-16d4-3f47-8040-37cdc7663a02",
    "path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/Ensembles.framework\/Versions\/A\/Ensembles",
    "name" : "Ensembles",
    "CFBundleVersion" : "1"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4333617152,
    "CFBundleShortVersionString" : "2.2.1",
    "CFBundleIdentifier" : "org.sparkle-project.Sparkle",
    "size" : 360448,
    "uuid" : "998f01d4-1e73-3cec-a0c6-5a49be01dbf5",
    "path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/Sparkle.framework\/Versions\/B\/Sparkle",
    "name" : "Sparkle",
    "CFBundleVersion" : "2017"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4329701376,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.hegenberg.BTTPluginSupport",
    "size" : 16384,
    "uuid" : "8544739d-8d4d-319f-bd3f-e505148b2242",
    "path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/BTTPluginSupport.framework\/Versions\/A\/BTTPluginSupport",
    "name" : "BTTPluginSupport",
    "source" : "P",
    "arch" : "arm64",
    "base" : 4329504768,
    "CFBundleShortVersionString" : "1.25",
    "CFBundleIdentifier" : "com.potionfactory.LetsMove",
    "size" : 16384,
    "uuid" : "4cccd167-7048-39ff-a5c4-594f5fa5e57a",
    "path" : "\/Applications\/BetterTouchTool.app\/Contents\/Frameworks\/LetsMove.framework\/Versions\/A\/LetsMove",
    "name" : "LetsMove",
    "CFBundleVersion" : "125"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4543365120,
    "size" : 49152,
    "uuid" : "3d687e9b-e092-3632-bc1d-74b19d492de0",
    "path" : "\/usr\/lib\/libobjc-trampolines.dylib",
    "name" : "libobjc-trampolines.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4564697088,
    "CFBundleShortVersionString" : "2.0.0",
    "CFBundleIdentifier" : "com.apple.iokit.IOHIDLib",
    "size" : 98304,
    "uuid" : "a8fe4691-d173-3b0b-8c08-0e0d938b0208",
    "path" : "\/System\/Library\/Extensions\/IOHIDFamily.kext\/Contents\/PlugIns\/IOHIDLib.plugin\/Contents\/MacOS\/IOHIDLib",
    "name" : "IOHIDLib",
    "CFBundleVersion" : "2.0.0"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4385816576,
    "CFBundleShortVersionString" : "3.0",
    "CFBundleIdentifier" : "com.apple.security.csparser",
    "size" : 131072,
    "uuid" : "fb85321b-0fa8-3ace-941c-abef6c37ff36",
    "path" : "\/System\/Library\/Frameworks\/Security.framework\/Versions\/A\/PlugIns\/csparser.bundle\/Contents\/MacOS\/csparser",
    "name" : "csparser",
    "CFBundleVersion" : "61439.81.1"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4388192256,
    "CFBundleShortVersionString" : "4.0",
    "CFBundleIdentifier" : "com.apple.security.ldapdl",
    "size" : 49152,
    "uuid" : "21ff6513-5fa3-3f13-b700-a9b58f85fbcf",
    "path" : "\/System\/Library\/Security\/ldapdl.bundle\/Contents\/MacOS\/ldapdl",
    "name" : "ldapdl",
    "CFBundleVersion" : "55005.0.2"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 5034885120,
    "CFBundleShortVersionString" : "324.6",
    "CFBundleIdentifier" : "com.apple.AGXMetalG13X",
    "size" : 6963200,
    "uuid" : "d03677d4-c896-3fd7-88c0-abed05133e06",
    "path" : "\/System\/Library\/Extensions\/AGXMetalG13X.bundle\/Contents\/MacOS\/AGXMetalG13X",
    "name" : "AGXMetalG13X",
    "CFBundleVersion" : "324.6"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6558199808,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5197824,
    "uuid" : "190e6a36-fcaa-3ea3-94bb-7009c44653da",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "3302.1.400"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6577016832,
    "CFBundleIdentifier" : "com.apple.Foundation",
    "size" : 14974976,
    "uuid" : "16d282d0-8b48-3e76-8036-fcb45dece518",
    "path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
    "name" : "Foundation",
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6620819456,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 21221376,
    "uuid" : "b88a44c1-d617-33dc-90ed-b6ab417c428e",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2575.40.6"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6563397632,
    "CFBundleShortVersionString" : "1141.1",
    "CFBundleIdentifier" : "com.apple.LaunchServices",
    "size" : 3047424,
    "uuid" : "0bd79215-03e1-3d88-8104-97d48bf358af",
    "path" : "\/System\/Library\/Frameworks\/CoreServices.framework\/Versions\/A\/Frameworks\/LaunchServices.framework\/Versions\/A\/LaunchServices",
    "name" : "LaunchServices",
    "CFBundleVersion" : "1141.1"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6747856896,
    "CFBundleShortVersionString" : "2.1.1",
    "CFBundleIdentifier" : "com.apple.HIToolbox",
    "size" : 3178496,
    "uuid" : "950f1236-acaf-379d-819f-6c6b0b5deabd",
    "path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
    "name" : "HIToolbox"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6554066944,
    "size" : 532288,
    "uuid" : "398a133c-9bcb-317f-a064-a40d3cea3c0f",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6840487936,
    "size" : 5914624,
    "uuid" : "a0ebe73e-3b7b-329e-985c-e884aba916df",
    "path" : "\/usr\/lib\/swift\/libswiftCore.dylib",
    "name" : "libswiftCore.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6557732864,
    "size" : 53248,
    "uuid" : "642faf7a-874e-37e6-8aba-2b0cc09a3025",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6557491200,
    "size" : 241656,
    "uuid" : "eee9d0d3-dffc-37cb-9ced-b27cd0286d8c",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6681997312,
    "CFBundleShortVersionString" : "944",
    "CFBundleIdentifier" : "com.apple.AE",
    "size" : 479224,
    "uuid" : "09e72a53-8b7e-3365-987b-3b6ca4f73672",
    "path" : "\/System\/Library\/Frameworks\/CoreServices.framework\/Versions\/A\/Frameworks\/AE.framework\/Versions\/A\/AE",
    "name" : "AE",
    "CFBundleVersion" : "944"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7801753600,
    "CFBundleShortVersionString" : "1.4",
    "CFBundleIdentifier" : "com.apple.ScriptingBridge",
    "size" : 98304,
    "uuid" : "74ac1f24-541d-3884-a0f7-ea1d89435393",
    "path" : "\/System\/Library\/Frameworks\/ScriptingBridge.framework\/Versions\/A\/ScriptingBridge",
    "name" : "ScriptingBridge",
    "CFBundleVersion" : "87.4"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6555963392,
    "size" : 290816,
    "uuid" : "5576e4fd-aad2-3608-8c8f-4eec421236f9",
    "path" : "\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7062327296,
    "CFBundleShortVersionString" : "20620",
    "CFBundleIdentifier" : "com.apple.JavaScriptCore",
    "size" : 25354176,
    "uuid" : "49a0e786-bb6d-35af-9d6e-f873c2746c66",
    "path" : "\/System\/Library\/Frameworks\/JavaScriptCore.framework\/Versions\/A\/JavaScriptCore",
    "name" : "JavaScriptCore",
    "CFBundleVersion" : "20620.2.4.11.6"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6649614336,
    "CFBundleIdentifier" : "com.apple.CFNetwork",
    "size" : 3969024,
    "uuid" : "446389be-e9e5-34d6-b055-567fab324e8b",
    "path" : "\/System\/Library\/Frameworks\/CFNetwork.framework\/Versions\/A\/CFNetwork",
    "name" : "CFNetwork",
    "CFBundleVersion" : "3826.400.120"
  "sharedCache" : {
  "base" : 6553255936,
  "size" : 4865835008,
  "uuid" : "5700d77a-6190-36e0-884d-fee6d586d62f"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.6G resident=0K(0%) swapped_out_or_unallocated=1.6G(100%)\nWritable regions: Total=6.7G written=1237K(0%) resident=1237K(0%) swapped_out=0K(0%) unallocated=6.7G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               128K        1 \nActivity Tracing                   256K        1 \nCG image                          4784K       64 \nColorSync                          544K       26 \nCoreData                            96K        2 \nCoreData Object IDs               4112K        2 \nCoreGraphics                        16K        1 \nCoreGraphics (reserved)             16K        1         reserved VM address space (unallocated)\nFoundation                       303.7M      300 \nIOAccelerator                       48K        1 \nIOKit                               32K        2 \nImage IO                         303.7M      598 \nKernel Alloc Once                   32K        1 \nMALLOC                             1.9G       80 \nMALLOC guard page                  384K       24 \nSQLite page cache                 9088K       71 \nSTACK GUARD                       56.3M       20 \nStack                             18.1M       20 \nVM_ALLOCATE                      128.1M        9 \nVM_ALLOCATE (reserved)             3.9G        1         reserved VM address space (unallocated)\nWebKit Malloc                    160.1M        3 \nWebKit Malloc (reserved)          32.0M        1         reserved VM address space (unallocated)\n__AUTH                            5306K      683 \n__AUTH_CONST                      71.1M      936 \n__CTF                               824        1 \n__DATA                            27.0M      930 \n__DATA_CONST                      25.3M      957 \n__DATA_DIRTY                      2752K      345 \n__FONT_DATA                        2352        1 \n__INFO_FILTER                         8        1 \n__LINKEDIT                       610.4M       14 \n__OBJC_RW                         2374K        1 \n__TEXT                             1.0G      980 \n__TPRO_CONST                       272K        2 \nlibnetwork                         128K        8 \nmapped file                      235.2M       41 \nowned unmapped memory              240K        1 \npage table in kernel              1237K        1 \nshared memory                     1456K       17 \n===========                     =======  ======= \nTOTAL                              8.7G     6148 \nTOTAL, minus reserved VM space     4.8G     6148 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "logWritingSignature" : "a124b637ee3d7618781bd8bf3cd0c4e490665890",
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "5fb4245a1bbfe8005e33a1e1",
      "factorPackIds" : {
      "deploymentId" : 240000021
      "rolloutId" : "63fe4dd2238e7b23a1f3067d",
      "factorPackIds" : {
        "SIRI_UNDERSTANDING_CAM_AB_TESTING" : "643938cae7268460c2e35a16"
      "deploymentId" : 250000004
  "experiments" : [
      "treatmentId" : "993c66e1-bf83-41fd-a09f-0d8d5906d223",
      "experimentId" : "664fc3cd79a61a0b8b557292",
      "deploymentId" : 500000013
Running killall BetterTouchTool && killall BTTRelaunch results in No matching processes belonging to you were found.
Note: I recently started experimenting setting up SketchyBar. This may be the cause or related to this issue. I'll quite SketchyBar and report back to you with my findings.
No the crash is definitely related to the file watching. Maybe it is again related to Full Disk Access? Which file have you tried watching?
mhh in that case the slowness etc. should not be related to BetterTouchTool, as it doesn't seem to be running anymore
I can't remember, I just started experimenting with it when BTT suddenly crashed and now I can't open the app anymore and keyboard input, my cursor, clipboard, almost eerthying is bugy
is it possible to remove this trigger without opening the BTT GUI? E.g. from the command line ?
I'm looking at $HOME/Library/Application Support/BetterTouchTool/Logs/com.hegenberg.BetterTouchTool 2025-03-28--07-31-59-416.log but 99% of the logs are 2025/03/28 00:42:12:228|ASL|No numeric part found in the filename.|
In on the west coast of the US at the moment so I'll get some sleep now. I'm sure after some rest I'll figure it out!
I should move the no numeric part logs, they are not really relevant ever :wink:
I think I might have found an issue in the library I'm using, should be fixed in the next alpha (can download via Index of /releases once it's up). Thanks for reporting & have a good night!
Not having BTT available is making me realize how dependent I am on your app :sob: :slight_smile: my mac is not usable anymore haha ! good night!
Hi Andreas, I confirm downloading the latest alpha from Index of /releases fixed the issue – thanks!
