Displaying results of shell script
This subject came up a couple years ago but after searching more I don't see where it may have been resolved.
I'd like to execute a shell script and capture its output for display in the HUD overlay.
I can create a StreamDeck button that shows the HUD and I know how to embed variables into the displayed text by wrapping them in braces. What I'm missing is, how do I assign the output of the shell script to a variable BTT can access?
It still works like described in the post you linked using the "Run Real Java Script" action. Here a full example:
(async () => {
let shellScript = 'date';
let shellScriptWrapper = {
    script: shellScript,
	launchPath: '/bin/bash',
    parameters: '-c',
	environmentVariables: ''
let result = await runShellScript(shellScriptWrapper);
let hudAction = {
  "BTTActionHUDTitle": "Test",
  "BTTActionHUDDetail": result, // the result of your shell script
  "BTTActionHUDDuration": 3
let hudActionWrapper = {
  "BTTPredefinedActionType" : 254,
  "BTTHUDActionConfiguration":  JSON.stringify(hudAction)
 await callBTT('trigger_action', {json: JSON.stringify(hudActionWrapper)});
returnToBTT(result);
However having the option to assign the result automatically to a variable is a good idea. I'll add that :slight_smile:
That would be awesome!
Thanks for the quick reply, @Andreas_Hegenberg.
In the latest alpha (3.9996) the result will be saved in the variable BTTLastTerminalCommandResult. I'll make that configurable in the future.
Depending on the action you use to execute the command / shell script, the execution will be async and BTT will not wait before it executes the show hud action. Thus you might need to add the "async delay" action .
Yep, that works perfectly, @Andreas_Hegenberg!
Interestingly, though, my existing Javascript solution using callBTT('set_string_variable... doesn't work under 3.9997. The variable no longer gets set. Just FYI.
that's weird, I can't think of a change that would make that not work.
It still seems to work fine here with a script like this:
(async () => {
    parameters: '-c',
await callBTT('set_string_variable', {variable_name: 'somevariablename', to: result});
No, you're right. Sorry to have wasted your time. I must've mucked something up. Both approaches are working now.
-- Robert
It's really difficult to find these things, we need to dig into the forum very deeply :slight_smile:
Have you found a way to generalize this problem, that is "how to pass the result of a script to the next action?"
That's a really painful point for me and anytime I don't write any BTT script for a couple of months then I forget
Could you add these general examples (the hud to display the result) to the doc until you create the generic "get result" workflow?
