I need a trigger the fires after the system wakes from sleep. I also need the system to go to sleep after x minutes. These are the givens.
Now as far as I understand there is display sleep (which can be set to activate after x minutes in Tahoe’s system settings) and system sleep (which can only be activated through manually clicking through the Apple menu in the top left). BTT does have a trigger but that is not listening to display sleep but to system sleep, rright? Can somebody help me to either put my computer to system sleep after x minutes of inactivity (which I guess could be rather complex on my end) or can I add the feature request to have display sleep enabled/disabled as a trigger (which would add complexity on Andreas’ side
