- Download https://github.com/lavoiesl/osx-cpu-temp and follow the instructions with
sudo make install - Create Widget/Gesture and select "Run Shell Script and Show Return Value"
- In Advanced Configuration, change Launch Path to
/usr/local/bin/osx-cpu-tempand set for every 5 seconds (or other you want) - In the Script Dialog, paste
osx-cpu-temp - Run script for testing.
- Use a cool CPU icon
