Hi!
First of, I really enjoy using BTT, thanks!
I would like to find a way to completely disable my Macbook Pro's (2020 M1 model with touchbar) click sound / haptic feedback it makes when I simply click on it (not tap to click but normal click).
It is so loud even on the Light setting that it just annoys me so much I am thinking about selling and getting a Macbook Air which has a much more solid and quieter sound when clicking.
Do you guys know if there is any functionality in BTT or elsewhere which could solve this?
Thank you,
Peter
Changing the feedback is not possible, it can be completely disabled though. However this is at the moment not implemented because it feels really bad if you don't have any feedback.
