"Disable BTT for x minutes"
Please add the ability to "Disable BTT for X minutes." @Andreas_Hegenberg
My BTT triggers sometimes interfere with a short task I need to do. It would be helpful to disable BTT for a few minutes and have it automatically re-enable itself after x minutes.
Currently, I disable it and then forget to re-enable it when I'm done. It would be even better if the number of minutes was customizable. Thanks!
Mockup:
you can create a trigger for that:
Thanks, that's great!
Most of the time when I have a feature request, there's already a way to do it. You should have an LLM trained on docs.folivora.ai and community.folivora.ai to answer these questions automatically. :slight_smile:
