Differentiate left/right modifier keys seems broken (v6.227)
Setting up the shortcuts works fine (left command and right command keys are recognized as such) but triggering doesn’t: a shortcut set up with left command+k is triggered by right command+k and viceversa.
Edit: please disregard for now; it’s behaving correctly again after a few restarts (one wasn’t enough). I’ll come back here if it reoccurs and I’m able to reproduce it reliably.
most likely something on your system has enabled "Secure Input Mode", BTT will show a warning about this when you click the menubar icon
Ah, thanks, that helps! I opened Terminal.app instead of my regular terminal app for the first time in forever, so that must have been it.
