Different battery charge actions
Its it possible to set several “charge goes lower than…” actions?
So like lower than 20 does A, lower than 10 does B, etc?
I have a solution for you but it may or may not be useful depending on your intentions. @GoldenChaos's touchbar preset has a nice battery widget whose icon changes based on battery percentage and charging status.
If you don't want to import her whole preset (as it's definitely large and a lot to sort through if you're already content with your setup), I've copy/pasted the code for this widget below. I'm not literate in shell script actions or JSON so I couldn't explain how to edit it if I tried, but here's how you set it up.
  1. Create a new Touch Bar item, select Apple Script/JavaScript Widget
  2. Copy the code below and paste it into the widget's code box under Widget Specific
  3. Under Common, copy/paste the button icon below into the Select Button Icon box - you don't need to set an Alternate Icon
If you wanted to configure actual actions to trigger at certain battery percents, I believe you'd go to the automations and other named triggers section and configure there, but I'm not sure.
Hope this helps :slight_smile:
set batteryStatus to do shell script "pmset -g batt"
set powerSource to word 4 of batteryStatus
set percentage to word 11 of batteryStatus as integer
set charging to word 12 of batteryStatus
if charging is "discharging" then
	if percentage is greater than or equal to 96 and percentage is less than or equal to 100 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAs0lEQVR42u2WQQrDIBBFh3iP0hRK7MHjLoucIT1LXCZt1uZ1FaglOx2o4NsIs3jgCP8rUqlU/hosPZ5ACoGZHvurblnJxcotljtgpMUk3d7QMgIuHnvgmmW9F2CORwEwIkxJC5lEMECI5cBxpvDtKlfOi4G7lhxgodOTw6Ap3zTlFCvfCn3QBasjfzPQlZ0teSL3eR65qmVx1FyTJG7Oa06zoEWwODx7knbH43jUj1qlUg4fxZ8lasabhQ4AAAAASUVORK5CYII="
	else if percentage is greater than or equal to 86 and percentage is less than or equal to 95 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2WQQqDMBBFg96jNIVienCzy8Iz2LOYpbau4+tKaGzpwjjQQN4mMItHMgPzo1ShUPhrMLR4AikEBlrMVq2ZOIqJSyy3QIemTnp9jaYDbFz2wPmQ9p6AIS4FoFaKfmcr+rfbQ4jlwHru49OVr5wHjquUHGCkkZODk5TPknKylc+ZDnTEyMifOJq8d0vqyr3/WrmiYbHGXJUkrr7HnGRAK4XB4lmStAsey6181AqFfHgB7SnFu8OCs/4AAAAASUVORK5CYII="
	else if percentage is greater than or equal to 76 and percentage is less than or equal to 85 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQqDMBBFg96jNIVienCzc+EZ7FnMUlvX8XXlIioUGwcayNsEZvGYTGB+lMpkMn8NhhqHJwZPT41ZqzUjZzFyC+UWaNGUUbcv0bSADcsOuJ4y3gvQhyUPlErRHR5Ct+kefFgClvMom97XteTkvGi4S8kBBio5OTSS8klSTrLyKdEHHTAy8jcNVdq75feV+/y+ckXDYom5Ikpc7MecZEArhcHimKO0Mw7LI3/UMpl0+ADW1WYbk5lWXgAAAABJRU5ErkJggg=="
	else if percentage is greater than or equal to 66 and percentage is less than or equal to 75 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQrDIBBFJblHqYUSe/C4yyJnSM8Sl0mbtXldZWFowGIGKvg2wgiPUWG+ShUKhb8GQ4vDk4JnpMXs1ZqZs5i5hXIL9GjqpNPXaHrAhmUHXE+53gswhiUP1EoxRB9+OOwefFgCtjWWw973e9nJedFxl5IDTDRycugk5YuknGzlS6YPOmFk5G86mrxny+8j9xk/ckXDYou5KklcfY85yYBWCoPFsSZpVxyWR/moFQr58AGRs+aMzl3kdAAAAABJRU5ErkJggg=="
	else if percentage is greater than or equal to 56 and percentage is less than or equal to 65 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQrDIBBFJd6j1EKJPXjcZZEzpGeJy6TN2ryusjAU0mAGKvg2wiCPUWG+ShUKhb8GS4MnkEJgoMFu1YaJs5i4xXIHdBh00uk1hg5wcdkD11Ou9wIMcSkAWin6H47d73QPIS4B67rPTu/bHdnJedFyl5IDjNRycmgl5bOknGzlc6YPOmJl5G9a6rxny5GR+zw6ckXDYo25KklcfY85yYBWCovDsyRpFzyOR/moFQr58AFAVIbsiXp9RAAAAABJRU5ErkJggg=="
	else if percentage is greater than or equal to 46 and percentage is less than or equal to 55 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlIlJEGgcayNsEhvCYSWC+SCaT+WswNDg8MXgGGsxWXTFxFhO3UG6BjooyavqSig6wYdkB11Oe9wIMYckDpQj97sD9oe7BhyVgPfc41Pv2XnJyXrTcteQAI7WeHFpN+awpJ1n5nOiHjhgd+ZuWOu3dcmzlPn9buaphscZcESUuvsecZkCLYLA4lijtgsPykEwmkwwfsQgnTIxdnPMAAAAASUVORK5CYII="
	else if percentage is greater than or equal to 36 and percentage is less than or equal to 45 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlImIpEgcayNsEhvCYSWC+SCaT+WswNDg8MXgGGsxWXTFxFhO3UG6BjooyavqSig6wYdkB11Oe9wIMYckDpQj9l1H7A92DD0vAeu5zoPft7eTkvGi5a8kBRmo9ObSa8llTTrLyOdEPHTE68jctddq75dfKfcasXNWwWGOuiBIX+zGnGdAiGCyOJUq74LA8JJPJJMMH497HnQsmWpMAAAAASUVORK5CYII="
	else if percentage is greater than or equal to 26 and percentage is less than or equal to 35 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlItouJA40kLcJDOQxk8B8kUwm89dgaHB4YvAMNJitumLiLCZuodwCHRVl1PQlFR1gw7IDrqc87wUYwpIHShH63ZD94e7BhyVgPbcc7n17Jzk5L1ruWnKAkVpPDq2mfNaUk6x8TvRDR4yO/E1LnfZu+b1yn/ErVzUs1pgrosTF95jTDGgRDBbHEqVdcFgekslkkuED2NZn/WdIKR8AAAAASUVORK5CYII="
	else if percentage is greater than or equal to 16 and percentage is less than or equal to 25 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtUlEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XVlIdqVcaCBvE1gII+ZBOaLZDKZvwZDg8MTg2egwWzVFRNnMXEL5RboqCijpi+p6AAblh1wPeV5L8AQljxQitB/h+sPdw8+LAHruXK49+3d5OS8aLlryQFGaj05tJryWVNOsvI50Q8dMTryNy112rtlv3Kf561c1bBYY66IEhe/Y04zoEUwWBxLlHbBYXlIJpNJhg+ixOhuQfsw9wAAAABJRU5ErkJggg=="
	else if percentage is greater than or equal to 10 and percentage is less than or equal to 15 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtElEQVR42u2VvQqDMBRGL/oepSkU0wc3m4PPYJ/FjNo6x9OhCI24xQsN5CwJ33DID9xPpFAo/DVYWjyBFAIjLXavNsycxcwtljugx1An3b7G0AMujj1wPeV5L8AYRwGoRRiAIfH0EOII2NbvLkG/N2Qn50XHXUsOMNHoyaHTlC+acrKVL5l+6ITVkb/paPKeLb8j93n2yFUti63mqiRxdVxzmgUtgsXhWZO0Kx7HQwqFQjZ8AFyxiM55BDSUAAAAAElFTkSuQmCC"
	else if percentage is less than 10 then
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAYAAAAacYo8AAAA10lEQVR4Ae3YMQ6CQBCFYQL3MGpiWE9g6WndjoLjWNpAiWq9jFM82rGcHfMm+RMLik8zBpZGREJGOOGEu0Y44YQn7abNWhG/KdoES/oFP2hPqWxgOlrwjAtHfInOcQU6GEaYsgWfcdG+oh3ewTQZcOw0fun79fKoAN7BVCz4Ng3g+OwehnA3+EsbtFM0+DaL1oeDY4ao8E9UuPwxnKvCP+eipUjwN25APW/5XvCwj7WBDhL20a11BLf20S3iYdl4PZGxNqsjdoUha2e+ySKc8AARTjjhQfoCLEebqfw1Zu4AAAAASUVORK5CYII="
	end if
else if charging is "charging" or charging is "AC" then
		set batteryIcon to "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"
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAYAAAAacYo8AAACNUlEQVR4Ae2YA8xdQRBGa7dRbTOorbA24tq2jahRjai2bds2gtp2eztJzkumutzy30nOj/d2vj3XiOc4zj+JFbfiVvyPYsWtuBUvKMwT7gifhCh1Wk1QUkjD30+9Gpn7Ni4FvcRzEWqizgjFCO8oTBIS8P/HIEE45XYTn8/AVSxEQgObsiyZxQP2JcRhFf3z3cTvMChnVGFIRt6xCBnZybjtIs4+zZqufanNHsEJyAQVeoy8kuR18+jd85M1zz7/U3GKD0JIb1SBi8i6SlZuPxk/kaN+jfgZISm9o1VWR7Ka/43iF4Qi9LUSdKUm67RB8WfCMiFfFPFHQlV6Kgu6ppCTTsNnFYUNIcVj9UQoEFa8KeNzCR9UxmdOhfHcQD6UOLUsjHhvddq7pdMQvy7cFe5p+H4McwyOKP4iqPhIFXQwxFU1qaE17gQR36lCNgeUvizEJ78Veb9NfAxjBjP+lfBS8YJd4rOjis8zkN1S5f2uXYU17k6pH4iXJLe68Fbl/daDc6dQkXHJhRQx6B8u6GrE2FLCDZUT9XRY0MQl/xa9iYTXKq8/eemFMwYuQM+5ABUwda/Sg96mKmuGytv7192rQAl6j5CzTWXNMnPJN39bO5agPGTcUNLDfGbsDXBba/xBYj0ZGfXn5h8k3B/dEgScJDf99QwIJ3B5dDP2sNyckHHCUP7OzKU9cuGU28/rifnsNp99hL6kL4VQQQVujyj7GYf5QiH7JssUVtyKW3ErbsWt+Bcm6kxE9j1EfAAAAABJRU5ErkJggg=="
		set batteryIcon to "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"
		set batteryIcon to "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"
		set batteryIcon to "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"
		set batteryIcon to "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"
		set batteryIcon to "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"
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAYAAAAacYo8AAAB6ElEQVR4Ae2YAURDQRjHa4sSBVBC2pK9AGUxSgAgQgwgEgxACElSQAAJAdAjDIMQZSxEBgVKCrQVUrUV1N71xX98pu65ve+pcR8/XnX3v1/vbu/erU0p1ZJYcStuxf8UK27FrbhD7BFloqaC1TkbIEn04vqZ0BbGLsHF8ROPIVSiLogxhGeIbSKCnz9NguAU14m7aJjDPxEVmMoUMscN+0XhkEN/VydeRqMhofXXhbxigIxBZJQ04ljTuNMzl4sFQvlQ0AxaRF4ygHgUGTWNOAq/gJgvvwTuI+taYOZQ4YtvsKxMq4gvELx6QhB/IbLESBDxRxY4TfDa4QKC4vV6IhLNiqfRPkZ8sAyPSIUpjso2I77EHnt3PA3iN8Q98cDB3zeFxCum4uss6LSJXbVTSFyZiOdZyKGh9BXRbiAtKl6f5hW0fyOqjAqWhNc4rUSf8BqvmN9xPRM/iCf/w4czT0xpBlsjeM2F9Dh0JHfODuKd5S0LPw5fsQElpLf8NMvabaV3lTPkHMlvQHKvtScNQcPIuNXLyL7WShwkDpDRLyHODxImR7eI4SBx9J8VEI7oj24yh+V5hGwRq7gewNauL6HD8jcO4WLZeMq/qujXTUyywOOAsh4cXGLUfpNlxa24FbfiVtyKS/EFcCypERicPW8AAAAASUVORK5CYII="
		set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAYAAAAacYo8AAAB0ElEQVR4Ae2YAUQDURjHa4smCqCEtCVbgLIYEQCIEAFEggGAkIQCAkgIgI4wDEIULEQGBUoKtBWo2gpq9/rwxyd51+195xzfx4/rde//ftu93bt3PcaYRKLiKq7isaLiKq7iBeKQaBId41ZXbIAiMYTj16COGLsBl0KQeBahEnVNTCO8TOwRKfz9HSYITjmbuIcTq/gQaYFLWULmTMh+aThU0d+ziTdx0rjQ/Msgr+6QMYaMhkUccxrf9MLNWo0wv6iFGLSOvKKDeBoZHYs4Cg1cmPPPAY+QdSdw5VDRi2+zrHJSxFcJXoMRiL8RFWJSSnye4LWPdmlxg3oh8q7iWeKLZfhEKUpxVMVFPEM88jSI3xNPxDMH/98REm+5iF90sar2C4mbbsVPQkrfEr3oG5v4Bs7/INqMFqaEb1ihfZhLxTZVLMz+IV6M/8cZzBbBaymi22FBUryP+GR568K3w3csQHnpJX+ZZR0k6VnlEjmn4guQw2PtecAgE8h44O3yj7XyG4ljZIzwdvmNhH3rlgo5SA79FwWEU5atm9hmeQUhu8QmjkextEsUNsvBryc8TBvfBFcb/QaIORZ45ijrw8EjpvRNloqruIqruIqruBQ/L0HEIEhS4cAAAAAASUVORK5CYII="
		set batteryIcon to "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"
		set batteryIcon to "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"
	end if
else if charging is "charged"
	set percentage to 100
end if
return "{\"text\":\"" & percentage & "%\", \"icon_data\":\"" & batteryIcon & "\"}"
icon
