"Did Open URL" does not work if url is opened from within BTT/named trigger
I have an action "Show / Choose From List (Configurable)" action with "Retrieve Content Dynamically via Java Script / JSON". The script is like:
async function retrieveJSON() {
    let items = [
            "title": “1111111 |  Sandbox | 11111”,
            "action": {
                "named": "open_aws_bookmark",
                "setvariable": {
                    "name": "custom_aws_sso_link",
                    "value": "https://myapps.microsoft.com/signin/11111111_AWS_APP"
            "title": “2222222 | Non-Production | 3216",
            "action": {
                "setvariable": {
                    "value": "https://myapps.microsoft.com/signin/22222222_AWS_APP"
    return JSON.stringify(items);
The named trigger which is executed:
    "BTTActionCategory" : 0,
    "BTTLastUpdatedAt" : 1748627332.250819,
    "BTTTriggerType" : 643,
    "BTTTriggerTypeDescriptionReadOnly" : "Named Trigger: open_aws_bookmark",
    "BTTTriggerTypeDescription" : "open_aws_bookmark",
    "BTTTriggerClass" : "BTTTriggerTypeOtherTriggers",
    "BTTUUID" : "D4217E28-43B9-4466-B31C-3CFBDE9A0A67",
    "BTTTriggerName" : "open_aws_bookmark",
    "BTTNotesInsteadOfDescription" : 1,
    "BTTEnabled" : 1,
    "BTTEnabled2" : 1,
    "BTTOrder" : 15,
    "BTTAdditionalActions" : [
        "BTTLastUpdatedAt" : 1748627304.185436,
        "BTTTriggerParentUUID" : "D4217E28-43B9-4466-B31C-3CFBDE9A0A67",
        "BTTIsPureAction" : true,
        "BTTUUID" : "8EDC7B73-A696-4583-8774-CD26AA1B7608",
        "BTTPredefinedActionType" : 59,
        "BTTPredefinedActionName" : "Open URL  or  Open URL With Selection",
        "BTTOpenURL" : "{custom_aws_sso_link}",
        "BTTOpenURLBrowser" : "Default",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 1
    "BTTIconData" : "",
    "BTTGestureNotes" : "open_aws_bookmark"
All of this is working fine, however I have automation to detect if specific URL has been opened:
    "BTTLastUpdatedAt" : 1748637146.7386088,
    "BTTTriggerType" : 682,
    "BTTTriggerTypeDescriptionReadOnly" : "Did Open: https:\/\/myapps.microsoft.com\/signin\/*",
    "BTTTriggerTypeDescription" : "Detect if AWS SSO link is opened. The variable set in the script is then used in floating menu. This work BTT have to be a default browser. ",
    "BTTUUID" : "8B6DD1E5-F3E2-4BB1-B1FF-011C89B8975E",
    "BTTDidOpenURLAdress" : "https:\/\/myapps.microsoft.com\/signin\/*",
    "BTTAdditionalConfiguration" : "https:\/\/myapps.microsoft.com\/signin\/*",
    "BTTEnabled" : 1,
    "BTTEnabled2" : 1,
    "BTTOrder" : 5,
        "BTTLastUpdatedAt" : 1731676204.0622339,
        "BTTTriggerParentUUID" : "8B6DD1E5-F3E2-4BB1-B1FF-011C89B8975E",
        "BTTUUID" : "8995DA6D-DDE9-4AE8-9E9A-EDE311E71111",
        "BTTOpenURL" : "{BTT_OPENED_URL}",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 0
        "BTTLastUpdatedAt" : 1748637158.5114899,
        "BTTUUID" : "9BD579EA-FD39-48D6-ACB9-FAF81CA600FD",
        "BTTPredefinedActionType" : 172,
        "BTTPredefinedActionName" : "Run Apple Script (blocking)",
        "BTTAdditionalActionData" : {
          "BTTAppleScriptRunInBackground" : false,
          "BTTScriptType" : 0,
          "BTTAppleScriptString" : "-- Get the BTT_OPENED_URL variable. This is possible because BTT is default browser and also links are opened via Alfred\nset theURL to get_string_variable \"BTT_OPENED_URL\"\n\n-- Use text item delimiters to split the string. This will work only if in the URL account_id is present\nset AppleScript's text item delimiters to \"_\"\nset urlParts to text items of theURL\n\n-- Extract only account_id. This will work only if in the URL account_id is present\nset extractedValue to item 2 of urlParts\n\nset_persistent_string_variable \"custom_var_account_id\" to extractedValue\n\nset_persistent_string_variable \"custom_var_account_id_url\" to get_string_variable \"BTT_OPENED_URL\"\n\n",
          "BTTScriptExternalPath" : "\/Users\/myuser\/Library\/CloudStorage\/OneDrive\/Documents\/btt\/scripts\/aws_account_id_extract",
          "SelectedAction" : 172,
          "changedFile" : "4D6A38DA-DE75-4878-9D25-E41EA72E1298",
          "BTTAppleScriptUsePath" : false,
          "BTTScriptLocation" : 3
        "BTTInlineAppleScript" : "-- Get the BTT_OPENED_URL variable. This is possible because BTT is default browser and also links are opened via Alfred\nset theURL to get_string_variable \"BTT_OPENED_URL\"\n\n-- Use text item delimiters to split the string. This will work only if in the URL account_id is present\nset AppleScript's text item delimiters to \"_\"\nset urlParts to text items of theURL\n\n-- Extract only account_id. This will work only if in the URL account_id is present\nset extractedValue to item 2 of urlParts\n\nset_persistent_string_variable \"custom_var_account_id\" to extractedValue\n\nset_persistent_string_variable \"custom_var_account_id_url\" to get_string_variable \"BTT_OPENED_URL\"\n\n",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 1
        "BTTLastUpdatedAt" : 1732020880.779737,
        "BTTUUID" : "BEB2F770-6550-4AA8-BFA8-71E47ADF39AC",
          "BTTTouchBarAppleScriptUsePath" : false,
          "BTTAppleScriptString" : "-- used to calculate how much time have elapsed since the URL was opened. This is then used in FirstFloatingMenu\/AWS Login time item\nset currentTime to (current date)\rset timeString to time string of currentTime\r\rtell application \"BetterTouchTool\"\r\tset_persistent_string_variable \"custom_var_current_time\" to timeString\rend tell",
          "BTTScriptExternalPath" : "\/Users\/myuser\/Library\/CloudStorage\/OneDrive\/Documents\/btt\/scripts\/login_time_aws",
          "SelectedAction" : 195,
          "changedFile" : "9A4C70EF-3E1B-45E4-8741-552BF0030028",
          "BTTScriptLocation" : 2
        "BTTInlineAppleScript" : "-- used to calculate how much time have elapsed since the URL was opened. This is then used in FirstFloatingMenu\/AWS Login time item\nset currentTime to (current date)\rset timeString to time string of currentTime\r\rtell application \"BetterTouchTool\"\r\tset_persistent_string_variable \"custom_var_current_time\" to timeString\rend tell",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 7
        "BTTLastUpdatedAt" : 1732021037.9246368,
        "BTTUUID" : "7A0187A8-86C5-4E2D-B2D8-B7E2E54E2C17",
        "BTTPredefinedActionType" : 292,
        "BTTPredefinedActionName" : "Assign or Set Value for Variable",
        "BTTVariableType" : 1,
        "BTTVariableName" : "custom_var_aws_timeout",
        "BTTVariableValue" : "60",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 0,
        "BTTOrder" : 8
    "BTTGestureNotes" : "Detect if AWS SSO link is opened. The variable set in the script is then used in floating menu. This to work, BTT have to be a default browser. "
and as you can see in the js, the value for each item in the list is URL is starting exactly with "https://myapps.microsoft.com/signin/".
However it seems that this automation is not triggered (not shown in "Recently used" as well) if I select an item from the list which will trigger the named trigger which is opening the URL :smiley: .
The same automation is working if the URLs are opened from Alfred.
Additionally however I've just noticed something strange - I think that the "BTT_OPENED_URL" variable's value is not correctly shown in the "Variables & Scripting", but otherwise it is working as expected, since I'm using it in a script and also the 1st action (you can see it in the screenshot) in the automation itself is to "Open URL" and the value used is "{BTT_OPENED_URL}"
this trigger "Did Open URL" will only work if url's are opened from other apps with BTT, but in this case urls are opened from/by BTT. I could probably add support for this, but need to make sure it can't cause weird recursions.
Nice, thank you. Do you have any idea about the other issue - why the "{BTT_OPENED_URL}" variable is not showing the correct opened URL from Alfred ?
yes, it was still using BTT's old variable update mechanism that didn't update the scripting view. Will be fixed with next alpha. Closing & reopening the scripting view should probably also work to refresh
Hey @Andreas_Hegenberg I have a smaller related issue. I am currently using BTT as a browser picker which works fine using “Did openurl”. I have the trigger modified with a pressed key so it only displays the picker when that key is pressed. How can I get it to select a specific browser from the list above when the modifier key is not pressed? Also, BTT can’t set itself as default browser and MacOS does not give you BTT as an option in settings, any insight into why that is happening?
bump..
