Detecting Application Expose in Advanced Conditions
Is there a robust way of detecting the Application Expose in 'Advanced conditions' like there is for Mission Control?
I think I can add a separate app_expose_active variable (Golden Gate only though)
Thanks, that would be great
Just checked and it's working, thank you for the quick response :slight_smile:
