Is there a way to define all these values via JavaScript completely? I’d like to run the script from my trigger without using this “default” action that I defined due to a need of setting custom height/width values per application and display type. Thanks!
I did look into Action JSON Definitions · GitBook but seems like there’s config missing. I’m not sure.
