Allow the "up" orientation of the trackpad to be rotated in 1-5º increments so that hands on a MacBook could be at a more natural angle during use.
unfortunately the driver only allows 90° increments ;-(
That's a shame, but thanks!
I just downloaded BTT version 3.508 (1646) and I don't see any trackpad options for 90° orientation changes, only the option to 'Mirror complete Magic Trackpad orientation for "upside-down" usage' which is basically a 180° orientation switch.
Am I not seeing where to enable a 90° orientation change for the magic trackpad or does this option actually not exist?
I've searched through the forums and docs but found no definite answer.
This is exactly what I need - 90 degree rotation of the trackpad orientation to match a 90 degree screen rotation (to portrait mode for books). Ideally I'd love to be able to rotate both trackpad and screen with one gesture. Please help!
Following on with what @jsore said.. I bought the latest version of BTT but I only see options for 180 degree rotate..
I did some searching on the forum and found this post from you saying 90 degrees is not possible..
Andreas_HegenbergAdmin
May '18
Unfortunately the trackpad drivers only support 180° rotation, 90° is not possible as far as I kno
If it is possible.. is there an option in BTT?
Thank you! (This is an incredible tool that has changed how I interact with my mac!)
