I have this bug since around 6 years using BetterTouchTool and I can't explain the reason, I can only reproduce it on exactly one Monitor (49" wide). First I thought - ok my installation is bugged (MacBook m1) so I haven't asked here.
Now, I did a full new blank installation on a complete new device (Mac Studio m2) but on the same monitor. I also took the original BetterTouchTool configuration (which is working on another device and monitor perfectly).
Description:
When I drag a window and move it, the custom snap areas should appear. On other installations, they do and they stay while I am dragging the window.
On this installation/monitor the custom snap areas "flicker" if they were redrawn several times and the dragging is just not possible because this redraw. I have to wait some seconds (may take 2-3 seconds or around 5-10 seconds or it just freaks out completely) and then the custom snap areas stay and I can move the window was I am expecting it.
There are some differences and maybe things I can say:
- just dragging without moving does not trigger the appearance of the custom snap areas and the bug
- dragging the window slooooooooooooooowly initially pixel per pixel (I mean around 1-2 pixel at a time in half a second?) will work most of the time.
- when the initial custom snap area keeps staying, I can move without any problems
- sometimes (around 1 of 10 times) it works pretty fine
Maybe there is a coincidence but since some weeks I have custom menu elements in the top right bar which should trigger a http url. When I click these items with the right mouse button (I am left hand user so normally that would be "left click") they are bouncing pretty fast and are flooding the http requests (as they are retriggered/redrawn?). If I use the left mouse button and klick them (again, that is then normally "right click") it's working fine. I also tried to use "debounce" but that's completely ignored.
Affected input device (e.g. MacBook Trackpad, Magic Mouse/Trackpad, Touch Bar, etc.)![]()
While testing this bug more in depth, it seems that it is only triggered by Logitech mice?
- G300S
- G903
I was not able to reproduce it with an Apple Magic mice.
But I was also not able to reproduce it with a Logitech G300s on another installation.
- Type of Mac: Macbook M1, Mac Studio M2
- macOS version: every between 2021 and 2026 I used
- BetterTouchTool version: every version since 2021 I used - currently 6.731
