Custom Plugin not working: NewConfigurationValues not invoked
For a Swift trigger plugin conforming to BTTTriggerPluginInterface, BTT instantiates the plugin and calls startObserving() and stopObserving() as expected, but didReceiveNewConfigurationValues is never invoked — neither at instantiation (to deliver saved config) nor after the user edits a form field and clicks Save.
Additionally, BTT does not appear to persist the form field's value: no plugin_var_* variable is created in the variable inspector, and calling delegate.getVariable("plugin_var_") from startObserving returns nil after the user saves.
The plugin is otherwise correctly recognized:
  • respondsToSelector:@selector(didReceiveNewConfigurationValues:) returns YES on the instance.
  • BTT's plugin manager does not log "Failed to load bundle" or "does not conform to BTTTriggerPluginInterface".
  • BTT's internal log shows "save", "saving", "did rebuild form" on the save action.
but our callback is never reached.
Minimal reproduction:
  1. Create a trigger plugin matching the structure of the docs' FileWatcherTrigger sample (with [String: Any]? → [AnyHashable: Any]? and .string → BTTFormDataString to satisfy the bundled BTTSwiftPluginHeader.h).
  2. Install, add the trigger, edit the field, click Save → callback never fires.
Related issues observed during diagnosis:
  • BTT caches the form definition per trigger instance: changing configurationFormItems() and recompiling shows the OLD form until the trigger is deleted and re-added.
  • BTTFormTypeCheckbox and BTTFormTypePopupButton both exhibit the same non-delivery as TextField.
  • BTTFormTypePopupButton additionally triggers a SwiftUI Array.== brk-1 crash inside AttributeGraph::LayoutDescriptor::Compare during form render when no defaultValue is set.
  • Setting formItem.autoSave = true on a TextField causes the field's contents to clear after every keystroke.
Affected input device
Not applicable — this is a Swift plugin / configuration-form issue, not an input device.
N/A (issue is in the plugin protocol delivery, not visible UI).
Device information
Type of Mac: MacBook Pro (MacBookPro18,4 — 14"/16" M1 Pro/Max)
macOS version: 26.4.1 (build 25E253)
BetterTouchTool version: 6.503 (build 2026050808)
Additional information
  • The plugin compiles cleanly against /Applications/BetterTouchTool.app/Contents/Resources/BTTSwiftPluginHeader.h. The header declares:
    -(void)didReceiveNewConfigurationValues:(NSDictionary * _Nullable)configurationValues;
    (untyped NSDictionary, imported into Swift as [AnyHashable: Any]?)
  • The defaultConfiguration() class method referenced in BTT's binary strings was implemented as an experiment and did not change the behavior.
  • Expected: didReceiveNewConfigurationValues: should be invoked at trigger instantiation with any saved config, and again whenever the user changes a form field and saves. Form-field values should be persisted by BTT and surfaced as plugin_var_* variables (or accessible via delegate.getVariable).
can you please try to add at least somewhat human description of your issue? This Ai generated stuff is not helpful as I don’t even know what you have been trying to set up. (it might be helpful as an addition)
Fair enough.
The issue is with the trigger based plugins written in swift. There are a few issues that are happening:
  1. The variables are not being created for configuration form values. As far as I understand (from the documentation), the variables should be created based on the field id.
  2. The trigger didReceiveNewConfigurationValues is not being called when the form values are changed and saved.
  3. The provided example for the trigger plugins does not compile due to the types.
For now I’m just using user created variables for configuration purposes.
Also, it seems that some of the stuff listed here does not work:
In particular, I am not able to get a description showing up.
