If I add a Custom AppleScript Slider to my Touch Bar setup, it comes with a default script of
return "0.5"
for the initial slider value. If I change it in any way (replace it or even just set the value to 0.6) and click "Save", the changes are not saved—open "Advanced Configuration" again, and the script will always have reverted to the above. Makes using the slider kind of difficult. ![]()
Touch Bar.
- Type of Mac: 2017 MBP
- macOS version: 10.13.5
- BetterTouchTool version: 2.512
