Hello! Please, I really need your help. I haven't found any information about Custom Apple Script Slider widget regarding:
- Logic of on bttWidgetSliderMoved(VALUE) ... end bttWidgetSliderMoved - what exactly triggers slider to send value? I know that it sends float in between 0 and 1 and I can use formula to change this value but if I quickly change slider position, it starts to produce wrong values [for example 0,25 - 0,38 - 0,54 - 0,14 (unexpected) - 0,68 ...]. Even if I quickly move slider from middle to the max position, sometimes the last value it produces is not "1", its value is 0,14 for example.
- How to trigger Real JavaScript when moving slider? How to use dynamic slider value in Real JavaScript?
- Is there a way to use some global variables that stays at the last value while Slider retriggers script (Applescript and Real JavaScript)?
It's really hard to non-programmer to find any information and ways to resolve issues.
Appreciate any replies. Thanks!
