Cursor Freezes After Using Trackpad Shortcut
Starting yesterday I keep having issues scrolling after using a trackpad shortcut. It’s on my Mac version 6.152. It seems to consistently take place if I use my shortcut that has three finger tip tapping. After I use the trackpad shortcut, when I try to move the cursor using the trackpad it’s frozen in place until I lift my fingers again and re-touch the trackpad. It happens even if my fingers are no longer touching the trackpad immediately after the shortcut. The first time I put my fingers down it won’t work, but once I lift them and try again everything is back to normal. I wasn’t sure if the problem was my Mac or BTT but when I turn BTT off it goes away. I have paste connected to that 3 finger tip tap shortcut. So I’ll paste an item in Finder and if I try to scroll back down the Finder page with the trackpad after, I can’t. It’s just stuck and then I have to lift my fingers and it goes back to working. I’ve used it for years and never had this issue.
what kind of shortcut do you have assigned to the gesture?
//edit: ah you mention paste, so cmd+v?
can you check whether your scrolling issue is resolved with v6.154?
