The current settings result in these upcoming trigger dates:
2022 M02 5, Sat 10:18:54 GMT+01:00
2022 M02 5, Sat 10:18:55 GMT+01:00
2022 M02 5, Sat 10:18:56 GMT+01:00
Also, Trigger "repeat in XXX seconds" is also not working - when I set it, it was not triggered
which version are you currently on?
There has been a fix related to cron triggers in the latest alpha - possibly try check whether this also fixes your issue.
