Critical issue; Rainbow-buffering-mouse-icon
Note:
Before bug reporting, please make sure you have tried the latest (alpha) version of BetterTouchTool and that you have already tried to restart your system :-). If you encounter a crash, please attach a crash log from the macOS Console.app's "Crash Reports" section.
->OK
# BTT 6.773 — synchronous Core Data fetch on the main thread causes system-wide input stalls
## Pre-report checklist
- **Restart tried — does not help.** This Mac was rebooted on 2026-09-06 at 12:10:46.
BTT diagnostic reports exist both before that reboot (07:12) and after it
(12:16, 12:49, 16:00), so the problem survives a restart.
- **No crash log is available, because BTT does not crash — it hangs.** The system
produced 4 `cpu_resource.diag` and 3 `hang` reports for BTT and zero crash reports.
The `hang` reports attached here are the corresponding artifact.
- **This IS the latest alpha.** The alpha feed declared in the app bundle
(`SUFeedURLHighSierraAlpha` = `https://updates.folivora.ai/highsierraalpha.xml\`) currently
publishes 6.773 / build 2026090402, dated Fri 04 Sep 2026 — the exact build installed here.
The release channel (`appcast.xml`) is still on 6.748, so this machine is running ahead of
the stable channel, on the newest available alpha.
## Environment
- BetterTouchTool **6.773 (2026090402)**
- macOS 26.6.2 (build 25G83), MacBookPro18,4 (M1 Max, 10 cores), 32 GB
- Settings store was migrated from 6.443 during the update
## Symptoms
All of these are **system-wide**, not limited to BTT's own windows:
- Keystrokes stall for roughly 3 seconds immediately after switching applications
- Korean/English input-source switching is delayed by several hundred milliseconds
- Periodic beachballs; typing freezes completely for seconds at a time.
**A three-finger tap on the trackpad triggers this within seconds, reliably.**
- Quitting BTT makes all three disappear at once. Launching BTT alone, with every other
input-related app closed (Karabiner, Hammerspoon, Logitech Options+, CheatSheet, RunCat,
Only Switch), reproduces all three.
## Steps to reproduce
The most reliable trigger on this machine is a **three-finger tap on the built-in trackpad**:
1. Launch BTT with the settings store described below (346 entities / 209 enabled triggers).
2. Let it settle for 30-60 seconds.
3. Three-finger tap the trackpad.
4. Within a few seconds the beachball appears and **all keyboard input stops system-wide**
for several seconds. The BTT window itself becomes unresponsive.
Switching applications, and switching the macOS input source (Korean <-> English), cause the
same stall in a milder form.
Important: **disabling all 71 gesture triggers does not prevent it.** A three-finger tap still
produces the stall with every gesture trigger turned off, which suggests the cost sits in the
gesture-recognition / notification-driven fetch path rather than in executing a gesture's
assigned action.
BTT's own log around these events (attached logs contain 85 `tiptap` lines and 24
`three finger click block` lines):
LMDrag|dragged after three finger click block
tiptap|candidate contact (resting finger down 1.94s)
tiptap|rejected: fingers 0.57 apart (max 0.55)
tiptap|rejected: resting finger moved / palm heuristics (f1 0.00/0.48 f2 0.52/0.24 ...)
Relevant trackpad settings on this machine:
BTTThreeFingerTipTapMinSpread = 0.03
BTTTpThreeFingerSwipeSensitivity = 0.3
tpThreeFingerDoubleTapDelay = 0.5
BTTAllowThumbIfAllFingersArePlacedSimultaneously = 1
Trackpad: built-in on MacBookPro18,4.
## Onset
The machine updated BTT 6.443 → 6.773 on 2026-09-06 at 06:54. The first BTT diagnostic
report on this machine is from 07:12 the same morning. `/Library/Logs/DiagnosticReports`
retains entries for other processes back to 09-01, and contains **no BTT reports at all
before the update**.
## Kernel evidence
Four `cpu_resource.diag` reports, each hitting the 90-second CPU limit:
| Time | CPU time / window | Average |
| 07:12 | 90 s over 176 s | 51 % |
| 12:16 | 90 s over 90 s | 100 % |
| 12:49 | 90 s over 103 s | 87 % |
| 16:00 | 90 s over 140 s | 64 % |
All four heaviest stacks bottom out in the same place — a synchronous Core Data fetch
running on the **main thread**:
-[NSApplication run] → main dispatch queue
→ _CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER_ (in 3 of the 4 reports)
→  BetterTouchTool
  →  -\[NSManagedObjectContext executeFetchRequest:error:\]
    →  -\[NSSQLCore executeRequest:withContext:error:\]
      →  -\[NSSQLiteConnection performAndWait:\]
        →  sqlite3_step  →  sqlite3VdbeExec
In the 16:00 report, **22 of 23 samples** are inside that fetch.
The `On Behalf Of` field names the processes whose notifications drove the work:
**iTerm2, KIM_Extension (the macOS Korean input method), and Only Switch**. This lines up
with the input-source symptom — every input-method event appears to trigger a fetch.
BTT's own log shows the corresponding cache work, e.g.:
BTTItemTrigger: cache updated - 0 trigger row(s) fetched (fetch error: (null))
## Why this stalls the entire system
BTT holds a CGEventTap. While its main thread is blocked inside the fetch, key events
cannot be forwarded, so every application on the machine is affected — which is why the
symptom presents as an OS-level input problem rather than a BTT problem.
## The store is small
The settings store holds **346 entities total (209 enabled triggers)**. A single fetch over
this should take microseconds, and the indexes are intact — 26 indexes on `ZBTTBASEENTITY`,
identical to a store BTT creates from scratch. `PRAGMA integrity_check` returns `ok`.
The cost therefore does not appear to come from any individual query being slow, but from
the fetch being executed **once per incoming notification, synchronously, on the main
thread**, at a rate driven by unrelated processes.
## Ruled out locally
- iCloud sync disabled → still reproduces
- All 71 gesture triggers disabled → still reproduces (so it is not action execution)
- No key-sequence triggers configured (0)
- Clipboard manager holds only 33 clips
- Store integrity `ok`; index set identical to a freshly created store
- Other input-tapping apps quit → symptoms gone; BTT alone → symptoms return
## Attached
- `diagnostic_reports/` — 4 × `cpu_resource.diag`, 3 × `hang`
- `btt_logs/` — BTT's own logs covering the period
Macbook Trackpad: 3fingers-tap function
  • Type of Mac: Apple M1 Max 32GB-Memory
  • macOS version: Tahoe Version 26.6.2 (25G83)
  • BetterTouchTool version: 6.773
this sounds a lot like an issue with the legacy experimental icloud/dropbox sync. You mentioned you disabled that, but it still shows up in the logs, did you restart BTT after disabling it?
//edit: ah your later logs show it disabled, but the hang diagnostics are all before that. Are you sure the issue still occurs with the sync disabled?
Hi, maker! I'm not sure, very sorry for this reply, becuz I forgot it after I downgraded BTT then the issue has been resolved.
I've just followed Claude Code's activities to resolve the issue and reported it to you.
