Creating preconfigured window layout and accessing that with a key shortcut
Hi I wanted a bit of a help creating this, wherein if I prss "cmd + k" it should open up arc on left half and notes on upper right half and mail on the bottom right half.
So basically, is it possible to create a preconfigured window layout of apps with a key shortcut?
(similar to this, https://www.reddit.com/r/macapps/comments/1irl1th/snapit_a_menu_bar_app_to_launch_your_apps_and/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1)
you can use the action "Save / Restore Window Layout", however it doesn't launch apps nor open windows that are not already there.
Got it, thank you so much!
