Creating BTT Button for Ejecting External Hard Drive
Has anyone been able to figure out how to create a Touch Bar icon to unmount/eject an external hard drive?
Any ideas would be appreciated.
Update - I just figured it out. You can setup a button to Command-E and that is the shortcut to eject the drive.
Have a great day.
Hi Rusty,
I'm interested in the same or similar feature, how did you implement your button? I imagine a solution where as soon as I plug a drive to the computer, a new button appears in BTT and when I hit this button, the drive will be ejected - is this possible? Or how did you do it?
Cheers, Martin
I answered your PM already, but he most likely just has a button that is displayed regardless of mounted volumes and calls up ⌘E whenever he wants to unmount all connected devices.
I was going to look into this, where a list of drives shows up and you can tap each to eject. It seems possible to make an “eject all disks” button and retrieve attached disks, I just need to figure out how to seperate the list of disks and target specific disks.
In the Finder app in the BTT configuration tool, I added a button for the eject short cut which is Command-E and then labeled the button Eject Drive. It was as simple as that. Tried a couple of other things that didn't work but this did.
@rusty @Fuechsl @Katertier
Coming to my AquaTouch preset soon.
