For apps that don't properly respect macOS's customized key bindings (e.g. Eclipse, Arduino, MS Office, etc.) I routinely go into BTT and set up specific keyboard triggers for those apps. The thing is it's always the exact same ten or fifteen triggers. What would be great is a way to define that 'set' of triggers, then be able to go in to an app-specific setting and say 'use that set' and I'd get them all at once.
Even better, if you just made applying a set a 'trigger entry' itself (i.e. a single row in the list of triggers), you could still add/customize/override them for that app.
e.g.
TriggerSets (New feature)
- MySooperTriggers (defines 10 shortcut triggers, including one for CMD-P)
- MyWindowsShortcuts (defines 6 shortcut triggers)
List of triggers for MS Office...
- Apply Trigger Set 'MySooperTriggrz'
- Apply Trigger Set 'MyWindowsShortcuts'
- CMD-ALT-Y -> Do something awesome
List of triggers for Arduino IDE...
- CMD-ALT-Y -> Build Project
- CMD-P -> SomethingNewOverridingCMDPInMySooperTriggerz
Hopefully that makes sense.
