I’m using BTT from SetApp. The app launches and immediately crashes. Following the crash, it will wait 10 seconds give or take, then crash again. Each crash causes the system to hang for about half a second. I have had to temporarily uninstall the application. This is reproducible on only my iMac, my MacBook Pro doesn't have the issue. The last Setapp update to BTT seems to be from August 5 2020, so I’m guessing this is a large component of the problem (I’ve seen newer builds come out since then).
N/A
- Type of Mac: iMac Pro 2017
- macOS version: 11.0.1 (20B29)
- BetterTouchTool version: 3.400
BetterTouchTool_2020-11-18-184742_Alexs-iMac-Pro.crash (110.3 KB)
