Its strange that the corner clicks on trackpad are now not working...by the way im using the newest magic trackpad...before I had some actions programmed with each of the 4 corner clicks and it worked perfectly...and now it doesnt do anything...its ignoring the actions...my trackpad is perfectly fine by the way.... im using High sierra...
thanks....
Ignacio
- Type of Mac:
- macOS version:
- BetterTouchTool version:
