It seems, that one app can only exist in one preset.
Therefore it is not possible to create different presets for one app.
the triggers you define inside that app are specific to a preset. For the app configuration itself the master preset is used.
Yes, thats right, but as you can see, the copy is done in the master preset "Default" and
the paste is done in the master preset "Microsoft Word" with no other active presets.
Ah I understand, I’ll have a look- that’s probably a little bug that I can fix later today!
Hello,
I also wanted to copy an already created trigger into my second BTT on my other Mac via Handoff.
How does that work?
Christian
standard copy & paste should work (cmd+c/cmd+v)
