Copy/Paste CAgroup Conditions and Assigned Actions
@Andreas_Hegenberg A small right-click feature that would be useful to me!
Just add a copy/paste options from the right click menu of a conditional activation group.
Should be doable :slight_smile:
You can already copy a complete activation group using cmd+shift+c, however before pasting it you'd need to edit these two values in a text editor:
  "BTTActivationGroupName" : "name",
    "BTTAppName" : "name,
hmm a bit confused there,
I guess based on last time's data loss I won't mess around with hacky techniques! (especially if the whole of my preset relies on complicated connections between CAgroups!):grimacing:
@Andreas_Hegenberg
In addition, Could you add a "Copy Assigned Action" in the same manner? Thanks!
The latest alpha 3.370 adds a context menu to the app/cag list which allows to copy & paste conditions.
